May-03-2014 09:14 AM
May-04-2014 06:27 AM
May-04-2014 05:21 AM
May-04-2014 05:16 AM
May-03-2014 09:04 PM
barth wrote:okgc wrote:
I know of a case where the air line for the parking brake had been chewed by mice so there was no air pressure to release brakes.
I'm a bit confused. Are saying that there is two braking system? The regular one and the parking one?
If there is only one system, then my air pressure is up and steady. One weel wants to move while the other one doesn't
May-03-2014 05:30 PM
May-03-2014 05:20 PM
May-03-2014 05:02 PM
May-03-2014 04:04 PM
May-03-2014 03:41 PM
May-03-2014 02:34 PM
May-03-2014 02:12 PM
barth wrote:From my experience it's been rust or a bad return spring or a flat spot a top of the cam. Make sure when you have the brakes relined that the shop uses the new parts in the brake kit. A lot of shops will use the old springs etc. when relining brakes.
I had the pads replaced on one of the wheels a month before storing it. I wonder if it is the new pads that are stuck
May-03-2014 12:02 PM
May-03-2014 11:16 AM
May-03-2014 10:37 AM
May-03-2014 10:10 AM
