My Holding Tank heater is flappin....
J_L_Rivera
About a 1/3 of the heater pad is hanging down on the blackwater tank.
What can I use/how would you reattach it?
yes, it's pretty dirty. I'll have to clean it first.
Thanks,
Lake Front Property
2007 Itasca Spirit 31C
2008 Crestliner 1800 Super Hawk
4 REPLIES 4
ron_dittmer
As far as I know, all waste tanks in a typical class C & B+ are completely exposed to the elements. A Super C might be different. Because it is so, many manufactures fully insulate their heated waste tanks.
Since you are down under gluing & taping, why not add a 1/4" thick silver-backed insulation blanket in the process so the heating pad is so much more effective? You can buy such insulation by the roll, cheap at home improvement centers. Between contact cement (or special 2-sided tape) and single-sided EternaBond tape, it won't go anywhere.
Don't forget to insulate the top of the tank as best you can. The better the coverage, the better the heat is retained inside.
EMD360
I put in my own heating pads and reinforced their adhesive with double stick 3M tape that is recommended for adhering solar panels to the roof. Yes, I cleaned everything well before I taped them on. I also put reflectix over the pads to insulate the heater a bit. My tanks are not enclosed.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
CharlesinGA
I have this same issue on my View. Spray adhesive does not seem like it would be enough.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
Old-Biscuit
Clean it up and clean tank area around the pad
Get a can of spray adhesive.spray light coating on tank and pad
Place pad against tank and hold firmly..........pressing pad flat
Then use EternaBond Tape around the edges making sure pad lays flat/tight against tank and to seal edges so it doesn't come down again
