Mystery coolant leak stops vacaton
AikenRacer
We were 2 hours into a 4 hour trip to the coast for a week. Received two alarms for low coolant level. Each time I added coolant to the tank. Gotta be a reason for it. I checked all the normal items, oil, leaks, water pump, etc. No leak anywhere. I called Cummins in Augusta. The mechanic said it could be the EGR cooler or the air compressor. Neither would you be able to see. He recommended to get the unit to the shop asap. So we turned around and drove home. Got the low level alarm one more time. Crawled all over the engine and saw no leaks. Taking it to Cummins on Tuesday. I did notice some signs of spray on my tow vehicle. Have any of you had a similar experience? Comments? Cost of repairs, etc.?
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
22 REPLIES 22
AikenRacer
Well, after a call from the local Cummins shop, the problem is a coolant leak in the air compressor. Bill est $3,300. Engine warranty went out last year, go figure. Only 23K miles on the coach. Between the shop and myself, we are going back to Cummins to see if they will consider helping with the cost due to the low mileage. Fingers crossed. Has anyone else gotten help from Cummins with a slightly out of warranty repair?
Jim
It might be funny to some of you about the use of 'Stop Leak' but it has it's place and it's worked for me several times over the years.
Once drove from LA to Portland Oregon with a coolant leak, stopping every 70 odd miles to add stop leak. It was exciting struggling to the top of the grapevine nursing that Lincoln engine along, but the downhill saved it as it cooled right down since I coasted nearly 10 miles downhill.
Another time drove my DP 35' Class A from Valdez up Highway 4 on a 6% grade for miles puking ATF from the tranni. Found some tranni stop leak here and there at convenience stores along the way and limped at 55 MPH all the way almost 2,000 miles to Prince George before I found a hydraulic shop that could make a new hose for me. Sold the rig 8 years later still running fine.
So the stop leak products do help in certain cases. I do not know why it's not allowed in a diesel engine with a rad leak...but I respect the advice of many here so don't expect I'd ever add a stop leak myself in future. With Coachnet, don't really have to either.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
moisheh
Or just add bananas. Oh, wait a minute bananas are for transmission noise!
Moisheh
DSDP_Don
Yeah.....lets take a $35000.00 diesel engine and throw a $2.00 can of stop leak in it.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Bikeboy57
Ok. That is good news. One more check to rule out internal engine damage. Drain a pint or so of oil into a clear jar. Let it sit. If there is coolant in the oil, it will settle to the bottom of the jar and will be visible. If you have any coolant in the oil do not run the engine. Coolant in thr oil will cause the bearings to seize.
Richard and Rhonda
1999 Newell
Subaru Outback toad
AikenRacer
No pressure coming out of the overflow....
Jim
With my 5.9 Cummins, turned out the mystery leak was way up front from one of the coolant lines to the dash heater. Turning off the two brass valves (one down low on the engine, the other up a foot or two) solved the leak issue temporarily. A couple years later, got around to fixing it and it turned out to be a rusted through short piece of steel tubing near the front of the rig. Cutting it back past the leak and adding new hose made a permanent fix.
Jim@HiTek
Bikeboy57
Does the coolant overflow bubble when the engine is running? If so you have a breach between the coolant and the cylinders.
Richard and Rhonda
1999 Newell
Subaru Outback toad
Ranger_Smith
RedRollingRoadblock wrote:
Good chance that using a leak stop product will clog the coolant filter.
Dennis12 wrote:
Dike radiator and system sealer. Made by Conklin. Tried the rest. I put it in my V8 7 years ago for a head gasket leak. Still running with no problem.
I have had several diesel pushers and have not had one yet with a coolant filter. Only my 6.0 Ford had one. Know some of the earlier Cummins had them in 2000 but not in 2012.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
Ivylog
. do NOT use stop leak in a diesel engine.
And why not??)
Upgraded with a 08 HR Navigator 45โ€™...
11178adm
believe the cummins mechanic, an egr cooler leak will cause a loss of coolant with no external leaks being visible, the coolant that doesn't vaporize going through the engine will go out the exhaust and get on the toad. do NOT use stop leak in a diesel engine.
RedRollingRoadb
wa8yxm
Going to dealer is likely your best option. Especially if warranty or service contract still in effect.
Have seen a lot of good information above. but since you made the appointment with the shop that is how I would handle it.
AikenRacer
I monitored the engine temp very close. It stayed below the half way mark which is normal.
