โOct-18-2017 07:53 PM
โJan-02-2018 03:28 PM
โJan-02-2018 03:14 PM
mlwinnig wrote:
Onan Emerald Series gasoline generator...
Supposed to run for 30 - 45 minutes a month under load...
Generator shuts off when tanks drops below 1/4 tank so generator can't run coach out of fuel...
Don't want to keep stale ethanol fuel in bus to exercise generator...
Not convinced fuel "stabilizers" work with ethanol and not easy to get to good fuel...
Thinking of adding a small auxiliary tank and bypass valve for the sole purpose of exercising genny. Looking for input. Does this make sense? Ideas on requirements / issues, etc..
Thanks!
โJan-02-2018 01:58 PM
Sam Spade wrote:centerline wrote:
the red stabil is useless on ethanol fuel.....
Interesting that the company that MAKES it does not say that.
They say that it was reformulated slightly a few years back to work with ethanol.
I'm sure that we all would appreciate you giving us a reference to look at that says it is useless.
โJan-02-2018 11:20 AM
โDec-24-2017 07:49 AM
โDec-23-2017 03:38 PM
dougrainer wrote:
YOU do NOT work at an Onan or RV service center. It can take less than 60 days for fuel to varnish and ruin a Onan Carb. Diesel's? never had a problem, but how hard is it to start your genset once a month for 15 to 30 minutes?. As to Portable gensets, SAME THING. Even your Lawn and Garden Gas powered equipment will be ruined in 30 to 90 days if you do not run them or add stabilizer to their fuel tanks. Doug
PS, I have a LOT more experience with these things than you do.
โDec-23-2017 02:00 PM
centerline wrote:
the red stabil is useless on ethanol fuel... the blue MARINE stabil is formulated for stabilizing ethanol fuels and is also more concentrated, so the same size bottle goes farther than the red stuff does..
โDec-23-2017 12:17 PM
โDec-23-2017 07:51 AM
โOct-20-2017 10:09 AM
โOct-19-2017 04:18 PM
dougrainer wrote:Ivylog wrote:
Exercising generators and Diesel engines every month is a waste of time and should go under urban legends along with changing your car's oil every 3000 miles. How can all these portable generators survive without being exercised every month??? I have a portable welder that's 50 years old and it sits outdoors and it can be years between uses. Its sat so long that I have to touch the leads to a battery to re-magnetize the fields to get it to weld. I have a portable generator that's 40+ years old and gets used every 5 years...maybe. My 14 years old 10k generator has never been run every month...doing that would interfere with sorting my socks.
I agree the gas today sucks and needs to be stabilized if storing for more than 4-5 months. I would shut off the fuel supply to a gas generator...add a valve if necessary and then run it till it stops. Open the valve and crank it up next summer and Go Camping. Putting the spices in alphabetical order will be a better use of your time than running a generator every month.:S
โOct-19-2017 04:08 PM
mfox20 wrote:
Before going to the trouble and expense of adding a second tank, just
disconnect the fuel line at the generator and hook up a 2-3 foot piece of fuel hose and drop it in a smaller gas can.
It will run fine pulling from a can on the ground. This was my method for testing for a fuel issue on my 5500 Onan Gas unit.
I guess you could add a tee and valve to the line and not have to disconnect the main line each time. Just introduces extra connections that could leak though.
โOct-19-2017 10:29 AM
โOct-19-2017 10:09 AM
