โAug-01-2013 07:58 PM
โAug-04-2013 05:17 AM
MrWizard wrote:So, I now have a running chassis of a 1978 Dodge Champion 25' motorhome. I believe it to be a class A since it's a cabover and the chassis is a much heavier build than a typical pickup truck. The title lists the GWVR as 12,500.Here, I found this......
1966 The lightest entry in the standard-sized trucks was the D-100. The half-ton and three-quarter-ton models had a new 128 inch wheelbase model for better weight distribution, and a choice of Sweptline or Utiline bodies; for 1966,
you have a 1978 NOT 1966
no mfg sat on a chassis for 12 yrs before building an RV
you could have a 78 RV built on a 77 chassis, this is every common, motorized RV's are titled by yr of completion/model not yr of chassis
most likely is you have an M-300 or M-400
it depends on the wheel base of the chassis
โAug-03-2013 01:01 PM
โAug-03-2013 12:22 PM
โAug-03-2013 04:38 AM
โAug-03-2013 12:06 AM
โAug-02-2013 12:53 PM
โAug-02-2013 12:44 PM
โAug-02-2013 11:27 AM
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
โAug-02-2013 10:10 AM
barnaclebill wrote:
W-300 was a 1 ton 4X4 pick-up or cab chassis...
โAug-02-2013 06:15 AM
โAug-02-2013 06:10 AM
โAug-02-2013 05:19 AM
โAug-02-2013 04:50 AM
