Nov-27-2014 07:52 PM
Dec-03-2014 06:14 AM
Dec-02-2014 10:56 AM
Dec-01-2014 11:32 PM
smkettner wrote:yeah.. I'm a poor example since my 10ga. is hardly 6' long
#10? I would be at #6 minimum. Do check the impeller is clear.
Dec-01-2014 02:02 PM
Dec-01-2014 04:49 AM
draboo wrote:I think 10 gauge is probably too small. You want the least amount of loss possible. Yes, you could run the wires under your coach in some protective corrugated wire loom and then drill up into the battery compartment. But you are safer to find a path through the insides of the compartments.
I have plenty of 10 gauge wire to hook up directly to the batteries. But the batteries are on the other side of the motorhome. Can I attache the new wire on the underside till I get to the battery compartment, then drill a hole? Originally this is what I wanted to do,but I wasn't sure how to go aboot it.
Nov-29-2014 08:16 PM
Nov-29-2014 07:57 PM
draboo wrote:
Has anyone run into what I m assuming is an overheating problem with a Flojet macerator? When I first got this unit, it worked wonderfully for about 4 or 5 dumps. But the last two times, it stops dead after a round 5 minutes of constant pumping.I have not let it run while dry.
Now I have to let it cool down for around 5 minutes between pumping sessions of about 5 minutes. I did read somewhere that the Flojet pump will stop if the voltage drops below 12 volts.
Thanks for any input,eh?
Nov-29-2014 06:57 PM
Nov-29-2014 05:41 PM
Nov-28-2014 09:06 AM
Nov-28-2014 04:14 AM
Nov-28-2014 02:22 AM
Nov-28-2014 02:10 AM
Old-Biscuit wrote:
Hair wrapped around impeller........
Need to disassemble head and clean impeller
Nov-28-2014 01:58 AM
