New Tire Date Stamp
philandmargo
I am in the process of buying new tires for my rig. 275/80 Michelin XZA3 plus - 22.5. The dealer installed the front two, but there was an inventory glitch and they had to order the other 4 which will be in next week. They let me take the rig home. I haven't paid for the tires yet. As I have read and been advised in these forums, I checked the date stamp to insure they are new. On one tire the stamp is clearly marked 23/13, which is what I was expecting. The other tire does not have a stamp. It looks like where the stamp should be there is a decal with a bar code. Has anyone had experience with this? I am bringing it up with the dealer on Monday, but I would like to have some ammo. Thanks
11 REPLIES 11
lryrob9301
03 RoadKing wrote:
lryrob9301 wrote:
Coyote74 wrote:
When I bought mine, I ask the dealer to show me date codes. He showed them all 6 setup with codes facing so they could be read on mh easily.
The OP stated he was installing Michelin XZA3+ tires. These tires are directional rotation so one side of the coach will have the codes on the outside and the other side of the coach will have the codes on the inside.
That's the first time I have ever heard that this type of tire is directional.
Look on the side of the tire there is an arrow and the notation " Rotation". Also you can call Michelin and they will tell you that the XZA3 is a directional rotation type tire.
03_RoadKing
Jim and Deb
The Furchildren Abby and Baylee
USAF Retired
2001 Newmar Mountain Aire
Sully2
My date stamps are on the side that has the whitewall.....:B
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
lryrob9301
Executive45
blangen wrote:
For future reference, before the tires are put on, I ask to see them and check the date on each tire. I've never been denied my request.
X2
Coyote74
Joe Taylor , Good Sam Life Member
FMCA #285032
2004 Winnebago Adventurer 38R
Life's a trip, RVing makes it an incredible journey.
parkmanaa
Make no mistake about it; every tire has the date molded into one
of the sidewalls (molded, not 'stamped')
blangen
tatest
wny_pat wrote:
They are only marked on one side of the tire. It is probably mounted so the DOT build number is on the inside or between the duals. Don't know why they do that. Sometimes I'd swear they do it on purpose.
Shop I use, policy is to mount tire on wheel so DOT codes are on outside. But outer dual wheel, outside of wheel goes inside of dual set. And outside of inner dual is between the two ๐Ÿ˜ž
Policy works OK for singles and front wheels on duallys ๐Ÿ™‚
Tom Test
Itasca Spirit 29B
wny_pat1
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
Chuck_Gail
DOT code date normally only on one side of tire. You need to crawl under and look at other side.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
