โNov-10-2014 06:56 PM
โNov-11-2014 09:51 AM
ron.dittmer wrote:
I think the Chevy gets that extra space by making the cab that much longer.
โNov-11-2014 09:50 AM
โNov-11-2014 09:39 AM
โNov-11-2014 09:19 AM
I had to push it beyond what was required in order to get a feel for what it will be like in real use
โNov-11-2014 06:14 AM
ericsmith32 wrote:This little tid-bit piece of a comment says a lot to me. I would not shop for a chassis first, then the house sits on it's back. But rather shop for the house first, then determine your options with the chassis. If you have multiple house contenders, then the chassis would help make the final choice.
.....we just started looking at floor plans then the chassis second.
โNov-11-2014 06:10 AM
โNov-11-2014 06:06 AM
โNov-11-2014 05:39 AM
โNov-11-2014 05:21 AM
โNov-11-2014 04:36 AM
โNov-11-2014 04:31 AM
tpi wrote:tpi above said it exactly as I would have said it. The engine is very noisy at high RPM, but the amount of time it is noisy is very little.
I generally don't come on here and crow too much about the E450 past the point that it is a durable workhorse. I'll agree it gets noisy at 4K+ RPM. Your post did get me thinking about the percentage of time it actually operates at 4000 or more RPM. At least in my case maybe a percent or two of the total run time. I don't even know if that is close but it isn't much. At least for me generally it is cruising along at 2500 RPM, and running into the low-mid 3000s under acceleration. For me the 4K RPM+ has come on grades, sometimes sustained, but frequently climbs grades in the 3000s. In general engine noise has not been a concern.
Enjoyed the review just the same.
โNov-10-2014 08:30 PM
โNov-10-2014 07:35 PM
