No water in Sink hot or cold
Skip_n__Stones
Super Odd!!! I has a leak in the connection to the hot water tank. Replaced the cracked check valve and put everything back in order. Tested the connections and no leaks BUT NOW!!! I have no water in the bathroom sink hot or cold both faucets!!! The shower works both faucets and the water for flushing the toilet works. The shower is to the left of the sink and the toilet to the right.
Not sure how draining the hot water tank and repairing the leak could cause this problem? Super ODD and frustrating
8 REPLIES 8
GHOST1750
All's well that ends well!!
Just Don and a Chiuahua called Dulce
2003 39' Tradewinds LE
2002 Cavalier tow
Korean Veteran, USAF
FMCA F357981
CC4C
GOOD SAM
Life is a journey, not a destination !
Skip_n__Stones
OMG!!!!! The screen!!! I knew the check valve was fine because ALL other water stations worked fine.....but still kept looking in the water heater cabinet for the solution. Simple solution, totally overlooked........thanks!!!!!!!!
jjjandrbaker
My buddy was just telling me about the same occurence in his camper. They found that the little mesh aerator in the faucet was totally blocked. Easy fix. Check it out.
Jim Baker
San Antonio, TX
travel blog and photos
rav
we also had the debris in the aerator screens - no water flow- I now have one of the hose washer's with the screen on it in every hose- saved my butt a few years back as they got a little liberal with the pipe dope paste when they replace the hose bibb's - the screen stopped it, cleaned the screen and continued to fill
Donna_and_Rob
Could your check valve be in backwards? They have an arrow on them to point the direction of the water flow. Just a thought.
2003 38ft Travel Supreme
350hp Cummins
rockhillmanor
Had the same thing happen to me. Called the mobile RV repair guy back.
He took the screens out of both faucets and I had water. :S
Couldn't believe that BOTH faucets at the same time could have particles fill each and every hole in those screens but it sure did.
othertonka
full-timer wrote:
Check the strainer on the end of the faucet. It may need cleaning.
Joe
X2, when you worked on the water heater you probably stirred up some calcium flakes and they passed on to the faucet and plugged up the strainer. Unscrew the strainer and clean it. Good luck
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
full-timer
Joe
An Indian and a Gypsy
Joe and Nancy
2002 34 foot Georgetown double slide Ford V-10
towing 2004 Chevrolet Cavalier 4 Down
