Noisy Air Vents - HELP
Moffittclan
I've got a loud "chirp" in my air vents when I run the A/C at the two highest settings. I'm sure it's a bearing or something in the fan, but I couldn't figure out how to get to it...any suggestions? I took a video of it so you could hear it but I'm not sure if I can post the link here...I'll give it a shot... YouTube Video
23 year Active Duty Air Force
Waiting to retire (when I'm done having fun)
Empty Nesting it starting Summer 2016
2003 Damon Escaper 40' 3 slides (my first Class A)
330hp Cat 3126E
2014 Jeep JKU (toad)
6 REPLIES 6
crasster
Try to find the blower motor and use some lube on that. Probably a bearing. Some folks decide just to change the motor... I'm more of an oil type until failure. Use a good oil though, not WD-40 which really isn't a lube.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Moffittclan
J-Rooster wrote:
Maybe some type of lube sprayed into the back of blower assembly will quiet it down?
I tried a dynamic lube through the vent with no help...
330hp Cat 3126E
J-Rooster
fcooper
Have you looked at the front firewall behind the front cap. My blower motor is easy to get to behind the generator access door.
It matched a blower motor for an 87 chevy van.
Fred
Fred & Vicki
St. Augustine, Florida
Moffittclan
old guy wrote:
my noise went away by it's self
That's what I hoped would happen but after 700 miles, it's still there...not constant, but every couple of minutes it will start again...
330hp Cat 3126E
old_guy
