Norcold 1200 LRIM External DC Fans
noleakman
I have an 06 National Sea Breeze Norcold 1200 LRIM fridge and had the cooling unit replaced and I was told the dc cooling fans don't work! They took them off and tested to a battery and both were dead I have never heard them run sense new! I am having trouble locating them! Norcold gave me one number but RV shops don't show it! 618856 Has anybody had to buy them and know where they got them!I would have thought that there would be plenty of them at RV dealers after a new fridge is installed!
18 REPLIES 18
ArchHoagland
Cooling fans
Here you go....
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Executive45
Thanks..I'd buy new ones on line and see if they will install them free for you. IMO, they should as they recommend replacement with the new unit. Won't hurt to ask. Should be less than 1/2 hour for them....Dennis
noleakman
They left the old fans on the cooling unit I am not sure why!
RayChez
lj2654 wrote:
I just added a computer fan to the cooling unit of my Norcold 1200LRIM. I used a paint roller aluminum screen, added the fan to screen with cable ties. Cut the screen down to proper size with a bent edge, fastened at lower frig bottom and ran a power wire to same plug as refrigerator plug is in. Now I can plug in when parked with power hooked up or with genset running.
I just have never been able to figure out why so many have had problems with the Norcold 1200 LRIM. I bought my coach brand new in 2003 and I have camped in pretty hot parts of the country like Laughlin, Nev. in the summer months and my Norcold has worked flawless. As a matter of fact I can not even hear the fans running on my Norcold 1200.
But I have seen other coaches and I assume they might have a heat problem with their refrigerators because when I was in Las Vegas in the summer months they had fans hanging out of the opening where the vent cover is.
Maybe I am just lucky!
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
SCVJeff
PICK ONE
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
lj2654
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
Executive45
Do you have the old ones out? or did the tech put the no good ones on the new cooling unit?
vegasfoodguy
noleakman wrote:
I had checked with a few RV shops and it seems they don't want to hook up anything but stock! I wish I was a good repair man to tackle that job or could find someone in my area that was interested in doing it! I hate to burn up my new cooling unit with it being so hot in Riverside Ca in the summer!
Why not call a mobile rv repair person, It seems they can do just about anything.
Terry
Monaco Diplomat, Cummins, 38a
Toad Grand Cherokee and Jeep Wrangler, Brake Buddy.
noleakman
Executive45
1. Ball bearing fans. Don't waste your money on cheap non bearing Chinese fans.
2. Fridge just needs to be moved forward far enough to access the back of the fridge thru the outside access hatch. Being a contortionist will help.
3. Any four hole fan will fit as long as they are the correct size. Usually 4".
4. Make sure they are 12VDC.
5. I'll get the number of the ones I used and post a picture later today.
6. Whoever did your cooling unit replacement sure did you a disservice by not replacing them at the same time. Every CU mfg recommends that.
7. If you can't find them anywhere else, HERE is a place to get them....Dennis
Below is a pic of the fans I used. Cost was $4.95 each. Since we spend time in Texas and Arizona I had added four extra ones on the roof. I have pics of that if you want them. I have since pulled the Notsocold out and replaced it with the Samsung 197 residential....:)
DSDP_Don
"noleakman"....Typically you have to pull the refer out to get to those fans. On SOME coaches, the outside opening may give you access, but I've never seen a coach that does.
As others stated, you can use a computer fan. Make sure you buy a good quality model so you don't have to do this again. Adding the switch that allows you to turn them on manually can really help in hot weather. When I had my Norcold, I added auxiliary fans that were left on 24/7 during summer camping.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
noleakman
Do you have to pull fridge out to reach the fans?
dougrainer
noleakman wrote:
How do you mount the computer fans the other fans are mounted with a bracket to the cooling unit pointing upward??
All such fans have 4 corner mounting holes. You just have to make sure the new fans are the same size as the old. AND make sure they blow UP. Doug
Trumpet_Player
If the original bracket cannot be adapted to the new fans, I used zip ties when I did the same modification you are attempting a number of years ago. Not that it matters, but it was on a National Tradewinds.
Safe travels.
2012 American Coach Revolution
