Norcold problem Fixed I think.
vegasfoodguy
Hi Friends,
New problem with Norcold 1200, Runs perfect on electric, plenty cold etc. Doesn't automatically switch to propane. Check light comes on, NO propane (Tanks are full) I turn on and off several times, doesn't light. Leave alone for 10 mins, turn on then smack the gas valve and it lights.
Any ideas?
Terry
I turned the gas valve off and on, Then blew the dirt from the burner,
seems to work fine, plugged in and unplugged, it works.
Thanks.
Monaco Diplomat, Cummins, 38a
Toad Grand Cherokee and Jeep Wrangler, Brake Buddy.
12 REPLIES 12
uncle_t
or simply replace the no cold with a residential fridge.
2020 Integra 36U
can am spyder or can am commander
BE PREPARED- NEVER BRING A KNIFE TO A GUNFIGHT.
Executive45
dougrainer wrote:
Executive wrote:
The only recall that makes sense is for them to pull out their cooling unit and replace it with the Amish one..like that will ever happen..:E......Dennis
lets see, replace the CU with an Amish, upwards of $1000 dollars. OR, replace the Gas Valve---$100 on a refer that is cooling correctly. ONLY makes sense to you. Doug
NOT the OP, Doug....NORCOLD !!....:S......Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Don_Don
Do you have the fridge set on Automatic?
dougrainer
dougrainer
No brainer----If you thump the gas valve and gas flows, the gas valve is defective. REPLACE IT. Doug
rooster2
Open up the box that has the flame. Lots of time rust falls down and shorts out the firing.
Peg_Leg
Try turning the valves on slowly. They have a pressure safety in them. If the pressure changes rapidly it will shut off.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Executive45
vegasfoodguy
Cruzette wrote:
Be sure to check and see if your Norcold refrigerator has been recalled on their website. A lot of the 1200's have been recalled,including ours. Our recall parts are on order now. Possible fire hazard!
What is the recall for? I had the updated heat sensor installed in January. Are they replacing the heating units?
Thanks,
Terry
Cruzette
It doesn't matter where you go in life.........it's who you have beside you :B
Judy and DH Ray
Boomer & Petie Pie
2004 Country Coach 40' Inspire "Da Vinci"
dan-nickie
Turn on the stove burners for a minute to get LP flowing first.
Dan and Nickie
2014 Forest River Berkshire 390RB
Old-Biscuit
Keep smacking the gas valve as needed..........
OR fix gas valve problem.
Contacts/terminals dirty.....loose...corroded
Gas valve solenoids sticking/binding
Gas valve sticking/binding
Dad used to whack the top of the ole RCA TV to make it work.
Finally had to buy a new TV
