โNov-13-2016 11:29 AM
โNov-27-2016 10:34 PM
usersmanual wrote:Fiverwheel wrote:
When you look at the back of the refer from the outside, Is the red light on at the front of that little black box?
if u read the op post he clearly says fridge works well on 120V just not on LPG
โNov-16-2016 07:06 PM
โNov-14-2016 06:32 AM
โNov-14-2016 06:19 AM
โNov-14-2016 05:24 AM
โNov-13-2016 06:22 PM
โNov-13-2016 03:34 PM
โNov-13-2016 11:46 AM
usersmanual wrote:Old-Biscuit wrote:
Unplug 12V DC leads...clean contacts & reinstall
Check what the DC voltage is going to fridge
Pull high tension wire (circuit board to spark electrode) and make sure it has good, clean tight contacts
Check spark electrode 'gap' and position...S/B directly centered over burner slots with 1/8" gap
12V must be fine as he clearly said it works on AC
could be the spark relay
โNov-13-2016 11:40 AM
โNov-13-2016 11:38 AM
