โOct-07-2016 10:55 PM
โOct-08-2016 08:33 PM
johnf wrote:
We have a tiffin 2016 32 SA res. Ref. Only problem was leaving the direct tv rec. On while using the inverter for the ref. Overnight otherwise seems to be enough battery power
โOct-08-2016 08:25 PM
hanko wrote:
any tiffin you order with a resi refrig will have 4 batteries
โOct-08-2016 08:06 PM
โOct-08-2016 08:01 PM
โOct-08-2016 06:29 PM
Sprig wrote:usersmanual wrote:
...what is the object behind jugs of water in the fridge?
Thermal capacity to potentially reduce shift the actual time that the compressor runs the most; towards may day-time instead of night-time usage.
Total energy use-age may be actually more (as there IS significantly more thermal mass in the unit), however, if that use-age is shifted to the time when solar is available, then less battery capacity is actually needed.
It might also be neat to hack the refrigerator electronics and set a lower interior temperature during solar production, and elevate the temperature during periods without solar production.
โOct-08-2016 06:16 PM
โOct-08-2016 01:21 PM
Winnipeg wrote:
We are kicking tires on a new MH. Yes, we want a new gas coach, so suggesting a used DP to solve this particular question is not on track.
The Allegro 32 gas coach has our eye, but we are wondering about only 2 batteries. It appears that almost all upper level gas coaches have residential fridges these days, and they mostly all have only 2 batteries. It doesn't seam like enough. We mostly desert camp without hookups.
When residential fridges first started showing up in DP's about 10 years ago, they were adding 2 extra batteries in addition to the typical 4 batteries that DP's had. LED lights have reduced the load, and maybe 6 batteries is not necessary, but 2 seams too little.
The problem is complicated by the fact that simply adding more batteries does not appear to be an easy task. The two that come with it are under the steps. Maybe replace those with lithium? The storage compartments are not very heavy gauge, so simply putting batteries in there may not be a good idea without reinforcing things.
Any comments on dry camping with residential fridge & only 2 batteries? What happens if your furnace comes on and further taxes the batteries? Any good battery upgrade solutions?
โOct-08-2016 01:12 PM
Sprig wrote:
I think a residential refer is a GREAT idea, now that there are decent solar panels available. So, that is where I would start FIRST, adding enough extra solar to accommodate the extra demands of residential.
Then, I'd fill both the freezer, and refer, with jugs of water up to the point where the remaining space is more then you normally use.
So, with the solar, and water, the night-time electric usage should be fairly low, provided the internal temps of the RV are reasonable.
Then, if not already, I'd replace EVERY single lite bulb with an LED equivalent to further reduce night-time loads.
I'll follow my own advice above, and put a Kill-a-Watt on my own over the next few days.
Bottom line, I really do think that a significant solar set-up, unless you expect to run the genset 24/7 for A/C, is the first step over adding extra batteries. Adding extra batteries is the third thing I would look at doing; and realistically, doing all three (Solar,LEDs,Batts) at once is the best approach.
โOct-08-2016 12:54 PM
โOct-08-2016 11:37 AM
โOct-08-2016 11:24 AM
Mile High wrote:
We came from an LPG 4 dr fridge with icemaker in our fiver to a residential. The residential has more room, but even with 6 dedicated AGM batteries (2 separate coach batteries) we are feeling the hassle a bit of not being able to leave it running without power. I get about 36 hours using the 2800 watt inverter and then the generator has to start. We never had to worry on our LPG.
We aren't real boondockers, but I do like to leave it in front of the house for a few days.
โOct-08-2016 11:00 AM
โOct-08-2016 10:46 AM
โOct-08-2016 10:01 AM
