Oil Change Cold or Warm after sitting thru Winter
GORVN4FUN
My Motorhome (gasser) has been sitting for 3+ months through a very cold winter (Chicago) without being started. It's time to change the oil, which I do myself. Here's the question... Since the oil has settled in the pan all this time, is it better to just drain it cold and change the filter or run the engine before changing the oil?
Current - 06 Georgetown 326DSF XL - Class A w/ 07 Ford Edge toad
3rd - 02 Dutchmen Classic 28FB-DSL TT w/Silverado PU & Expedition SUV
2nd - 99 Wilderness Lite 22' TT w/Dakota PU
1st - 87 Palomino Slide-In TC w/Toyota PU
13 REPLIES 13
Blaster_Man
wolfe10 wrote:
And, next year, much better to change before storing, so the acids in the oil don't sit in the engine over the winter.
Good advice.
2014 American Eagle
time2roll
I bet if you have a sample tested they will say to run it another year.
down_home
Run it several miles to get it hot and then let it cool down to where you can handle it. Our diesel gets very warm. Everyone servicing it has had to let it cool a bit.
Always changed it warm. Anything that might have dropped out of suspension will go back into it and come out of the drain. Misture over winter will be in the oil or bottom of pan or filters or somewhere.
wny_pat1
Never change cold!!!
“All journeys have secret destinations of which the traveler is unaware.”
pianotuna
Nomad III
Nomad III
X2
Regards, Don
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
GORVN4FUN
I agree with the consensus to change warm. Just thought I'd check. Thanks everyone!
pianotuna
Nomad III
Nomad III
Hi,
I think hot is better. Drive for an hour at highway speeds.
I suppose one could use a magnetic "stick on" block heater?
Regards, Don
Bob___Ann
Always best to change oil as warm as possible. If you get it very hot be careful to not burn yourself. It will drain faster and pull any trash out with it.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
MitchF150
I'd warm it up first (full operating temp too)..
When the oil settles at the bottom of the pan, all the contaminates and 'sludge' form down there too and won't drain out when it's cold.
You'll get the bulk of the cold oil to drain, but it'll leave whatever has settled to the bottom of the pan on the bottom of the pan...
I used to drain cold oil and the new oil would turn 'dark' again pretty fast.. Started doing the warm oil drains and after a couple of changes, the new oil would stay 'cleaner' longer...
Just my experience with it and no 'scientific' proof what so ever.. Just what saw the color of the new oil did... 😉
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
Sully2
I re-do my oil BEFORE I put mine into winter hibernation. If you have to...then just wait and get a few thousand miles on the rig and pull into a place that does oil changes and have the oil and filter swapped out
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
Wrong_Lane
I was always told to change it while hot or warm as the warm oil will carry any debris out the drain.
Cold oil is pretty thick. My son changed cold oil on a small tractor this winter and it took over 20 minutes for the oil to drain out.
2006 Damon Challenger 348F Ford V10
2013 Ford Taurus SEL AWD
Blue Ox Aventa & Brake Buddy
midnightsadie
I
