old slide rule analog thermostats
mscamping
2003 moho with Duo-Therm thermostats.. They are acting crazy so I'm wanting replace them..
Isn't there a digital house thermostat that you can replace them with?
Do any of you remember which one works?? Thanks ahead of time..
Mike Mathews
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2013 Equinox w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
7 REPLIES 7
bluwtr49
I had changed the thermostat in my 2000 to a White Rodgers heat pump thermostat and wired the fan high speed to the 2nd stage connection. Worked perfect and the fan automatically went to high speed when the conditions were met for 2nd stage operation and back to low speed when the conditions called for one stage operation.
Now I have basement air which is two stage and am currently trying to do the same thing but it's not as easy.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
MountainAir05
Also look at the Comfort Control Center from Dometic. Several goods write up here on the forum.
http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=66938
Dutch_12078
Mandalay Parr wrote:
Why not just put in a new original analog one. Direct replacement. No fuss or muss.
Why spend $30 or so for the OEM analog stat, when the $20 digital stat works better and takes no longer to install if you skip the fan switch mod?
Dutch
2001 GBM Landau 34' Class A
Old-Biscuit
Changing out old analog t-stat with a digital t-stat is simple mod and results in a tighter heat/cool cycle (+/- 1* vs 5* with analog)
Digital Modification
Seeing as I never used the 'low speed' fan setting for A/C I didn't bother with the install of toggle switch....just wired A/C Fan for high speed only
Mandalay_Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Dutch_12078
I replaced the two Duo-Therm analog thermostats in our coach with Honeywell RTH2510B 7-day programmable thermostats. I modified them by adding a mini-toggle switch on the side to add the missing two-speed A/C fan control. They're powered by two AAA batteries that last around a year. I bought them at Home Depot for about $20 each. I've also seen them at Walmart for about the same price.
Dutch
