May-28-2014 01:54 PM
Apr-03-2015 02:34 PM
Apr-03-2015 01:19 PM
stan909 wrote:Yes I got it repaired at an RV dealer that specializes in working on the older classic GMC RV's that also had Onan generators. Total cost was $500.90 for dropping the generator and VR - $260 of that was for the potted electronic voltage regulator (some are charging over $400 for just the VR). Since my generator repair I have diagnosed the same identical problem for two other Roadtrek owners - this costly repair does not appear to be that unusual at all and according to my mechanic the main board with the starter switch (mother board) and VR are common repairs for the Onan. I also discovered that it is possible for you to replace the VR without dropping the generator, but replacing the two VR screws will be very difficult (some replace just one). Another approach I have seen is mounting the new potted VR on the outside of the Onan case - this method would be a much easier repair and could easily save you $500, since some are asking $750 and up to drop the generator and replace the VR.
Did the OP ever get his fixed ? I wonder.
Apr-02-2015 08:40 PM
Apr-02-2015 09:27 AM
Apr-02-2015 09:23 AM
Apr-02-2015 09:00 AM
Apr-02-2015 08:58 AM
Apr-02-2015 06:06 AM
May-31-2014 06:13 AM
May-30-2014 12:12 PM
powderman426 wrote:Jim&Carolyn wrote:
What exactly do you mean by "older" or "newer" model? I don't see mine as a "newer" model.
What I meant was if it had electonics on it such as led or trouble code by number. The older units from back in the 70's and possibly the 80's had no troubleshooting features built in.
May-30-2014 12:03 PM
May-30-2014 07:05 AM
May-29-2014 05:14 PM
May-29-2014 04:44 PM
