Apr-04-2015 06:11 PM
Apr-07-2015 01:57 PM
Apr-07-2015 01:06 PM
Ivylog wrote:
Hypoxia is correct that MH's are allowed to have 24K rear axle since 2012. This does not mean that all MHs since then have 24K axles nor can you safely put 24,000 lbs on a 20K axle.
FireUP was 2500 lbs over his rear axle rating and probably withing his tire ratings so the world did not stop spinning, BUT he only did it for 8K miles.
OP, I realize there is nothing we can say about this as you have made your mind up. I am not hung up on going over a rating... it's just a mater of which one and by how much. You will not post what rear axle you have or how much CCC. You did let it slip that you only have a hitch rated for 5,000 lbs and we know that it is not used to mount the lift, BUT that small amount would concern me.
So, for the third time: How much CCC and what is your rear axle rated at (it's posted besides the driver's seat)?
You posted: "Problem is that the combo weighs about 7000 lbs wet and the coach is only rated to tow 5,000." For what's it's worth, I would come closer to exceeding this rating than putting 1300+ lbs that far back on the MH. By adding a V brace to the 5K hitch I'd put the bike in the back of the F150 and not worry about overloading the rear axle of the MH.
Apr-07-2015 12:14 PM
Apr-07-2015 10:49 AM
BigGuy82 wrote:hypoxia wrote:John S. wrote:
It is 20k per axle not total weight.
That information is obsolete.
23 USC 127
shall not apply to-
"(C) any motor home."
(A) Weight limitations.-A covered State, including any political subdivision of such State, may not enforce a single axle weight limitation of less than 24,000 pounds, including enforcement tolerances, on any vehicle referred to in paragraph (1) in any case in which the vehicle is using the Interstate System.
Great information - thanks! Of course, it also points out the absurdity of the legal system in this country. Who, except the lawyers, could ever keep track of all this stuff?
Back to the original point of this post, I finally had an in-depth chat with both the general manager of my motorhome dealer and the owner of Overbuilt. Both feel that based on hundreds of installations on single axle pushers (especially the Freightliner XCS chassis) there will be absolutely no problem with this setup. Customers report no problems, little (if any) noticeable lightening of the front end and no blown tire or control loss horror stories. Specifically I ask about overloading the remaining tire in a blowout and the comments were that the additional 1300 pounds I'm putting on the ass end won't make much difference one way or the other. If a rear tire actually blows, it will always put tremendous stress on it's mate (which really tells me if a rear tire blows, replace the pair). End of the day, I'm going forward with this and I'll post my experience once I have it.
Thanks!
Apr-07-2015 07:17 AM
23 USC 127
shall not apply to-
Apr-07-2015 07:13 AM
Apr-07-2015 06:38 AM
Apr-07-2015 05:38 AM
John S. wrote:
I think you will be overloaded with the lift on. Can you do, sure you can. Would I do it, no. I looked and did the numbers and got a smaller bike and a versa haul ramp. Much lighter setup. You are stressing your unit and if you are only rated for 5000 pounds towing your frame setup is not going to hold a 1000 pounds tongue weight. It is your coach, so do as you wish but it is too small a coach to put the big bike on the rear.
Apr-07-2015 05:34 AM
Apr-07-2015 05:30 AM
Apr-07-2015 05:02 AM
jerseyjim wrote:
Forget the math! Get a good pickup truck (for a toad) and go from there!
Apr-07-2015 04:35 AM
Apr-06-2015 08:07 PM
okhmbldr wrote:
I don't think I noticed anything about the tongue weight capacity for the hitch.
If you have a 5000# hitch, then the tongue weight will be about 500#, 10,000# hitch, then TW of about 1000#, maybe more, just check the specs from the hitch manufacturer. If your tongue weight limit was 1000#, then I think I would rethink adding 1600+# on the rear.
Apr-06-2015 06:21 PM
