Tiffin Zephyr overheated. Towed to Freightliner shop. Fan wasn't coming on. 6 weeks to get part rebuilt, still not fixed. Towed to second shop and after a day of working on it they can't figure out the configuration of the system. Does anyone have an idea?
Dana and Judy 2000 Tiffin Allegro Zephyr 2012 Jeep Wrangler Unlimited Sahara
I had a 2005 Frtlnr chassis with side radiator. It had a tendency to overheat. I took it to Gafney, SC, Frtlnr motorhome guys. From the factory the fan modulator was missing. the main thing I learned was that the radiator and cooling system were marginal and the rpm's had to be kept between 1800 and 2100 while in any kind of grade or steep terrain. This was more evident in the earlier chassis, but it solved the problem.
Rod and Candy 2008 Holiday Rambler Endeavor 40' 400 ISL, GMC Envoy toad, Lucky Lukas the Miniature Schnauzer
Freightliner should be able to plug their computer into the data port and check the fan signal out of the computer/controller. Then you have the wiring and hydraulic servo valve in tthe circuit. Course you need good hydraulic pressure as well.
Please keep us posted.
Jerry Parr Full-time 2005 Mandalay 40B Cat C7 350, 4 Slides Blue Ox, Brake Buddy 2004 CR-V Toad jrparr@att.net 602-321-8141 K7OU - Amateur Radio Kenwood Radios ARRL, W5YI, & LARC VE SKYWARN Weather Spotter
Call Freightliner 24/7 Help Line. Forget his email ****. If it is on a FL chassis then They know all about it. When you call, be at the shop, then speaker phone.
Dale & Susan DaGirls II Rv - Dakota & Tilly Traveling Companions. 2008 Alfa Gold, 2015 Ford F150 XLT Roadmaster and Air Brake System 1600 Watts, Magnum Inv/Chg&Solar 800 Lithium Battery DaGirslRV Blog
Here is a product to eliminate some of the issues with the side radiator coaches. It senses the temperature of the coolant at the thermostat and tells the engine fan when to come on. It will allow the engine fan to run at variable speeds, which will increase mileage.
Take a good look at this product as a solution to your problem.
