โApr-29-2013 11:11 AM
โMay-01-2013 09:35 PM
โApr-30-2013 04:48 AM
Ivylog wrote:
Unfortunately the ground in NH will freeze well below 24" unless it gets covered with snow early in the season. 24" deep is not going to stop it from heaving if water gets in. For some reason if they heave, they go back down come summer.
โApr-29-2013 05:00 PM
โApr-29-2013 02:48 PM
rgatijnet1 wrote:On mine I just open up the door and drive it in plug it in.Supercharged wrote:rgatijnet1 wrote:I would just buy 4 stepping stones, should hold a 767 without any problem.Ivylog wrote:
24" deep and two layers of rebar???????? It's not a 747. OP, after sawing the 24X24 pads (you can use a cheap blade on a circular saw) only dig down 6" and go get some bags of extra strength Sackrete form HD. Even on FL sand this is thick enough and no need for rebar. At least you will not have to measure where to put these pads. Might want to mark where you tires are to make it easier to reposition the MH.
That is why you are NOT a contractor. The OP is in New Hampshire and the ground does freeze up there from time to time. Pour it the way you are recommending and it will "heave" the first time the ground freezes.
Stepping stones over a crater in the asphalt would probably break as soon as you started applying the weight.
โApr-29-2013 02:32 PM
BillMFl wrote:
At home I used crushed concrete gravel to make two 5x10' pads that support the front and back wheels and jacks. It was much cheaper than concrete and 4 yds of gravel was less than $200 delivered. Next to my concrete driveway I dug out the sod and shoveled the gravel myself. No worries about cracking or settling. A few shovel loads will relevel whenever needed. I used free oak mulch from a tree service between the two gravel pads so the coach wouldn't sink into mud if it happened to rain hard just before I was leaving or returning. Nothing fancy but it works just fine. Total length of the mulch and gravel is about 50'. Rain perks thru both the mulch and gravel. No mud and no puddles.
โApr-29-2013 02:04 PM
โApr-29-2013 01:49 PM
โApr-29-2013 01:37 PM
โApr-29-2013 12:51 PM
โApr-29-2013 11:55 AM
โApr-29-2013 11:32 AM
โApr-29-2013 11:18 AM
