Plumbing Repair Question
Racorman
I'm in the middle of replacing a couple of the water lines on my 2013 Itasca MH. I took this photo of the lines at the back of the water heater.
Many of the connections I can unscrew...... but I can't figure out how to release these connectors shown with yellow arrows. Unfortunately I have very little area to work within.
Any suggestions on separating this connections. And if I'm able, can I reconnect them once they are separated?
AKA..... 56Nomad
2012 Itasca 30' Class A
2013 Jeep 2dr Wrangler
7 REPLIES 7
Pass42
sometimes you also have to push the tubing into the fitting before it will release, in addition to depressing the ring.......
2017 Montana High Country 375FL
2015 Ram 2500 Heavy Duty, Cummins 6.7, factory tow package, factory snow plow prep package
2010Liberty
an open end wrench that will just fit over the PEX may be used to depress the yellow ring
dougrainer
Old-Biscuit wrote:
That looks like a SEA TECH Quick-Connect Fitting (by Watts)
Push down on 'collar' with one hand while pulling pipe out with other hand.
Re-usable fittings.
Unscrew the one fitting on line coming out of fitting so that you can have push/pull room
Correct, looks like whoever installed the fittings did NOT install the "C" lock clips. Doug
Old-Biscuit
Re-usable fittings.
ocean_bound
looks like similer to a shark bite fitting you could buy the little u shape tool to remove the fitting at home depot u need to compress that yellow ring the arrow is pointing at and pull should come right out
Allen&carrie 2006 georgetown XL359 37ft
bobcatcharlie
IF that is pex tubing, you should be able to push the yellow ring in and pull out the tube. It should snap back in to reconnect. That's how my pex works.
2004 Dutch Star
Kayteg1
I think this one should do the trick
http://www.homedepot.com/p/SharkBite-1-2-in-Disconnect-Clip-U710A/100638139
