I went completely through the suspension last winter. Freed up all the stuck zerk fittings, replaces front and rear sway bar bushings and a bunch or other rubber parts. Big difference in the ride.
The previous fall I had the local CAT shop do the 100,000 miles valve lash adjustment.
Last spring I replaced the house and chassis batteries and added another 100 watts of solar.
Looking into the future...
Clean out and re-brush the Onan 6500
Give the radiator and CAC a thorough cleaning. I just sprayed it out last spring. Need to shoot some Simple Green Extreme in there.
I'm sure the fuel pump will need replacing soon. I can't decide if I wait for it to give up or if I do a preemptive strike.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
