โNov-23-2019 11:33 AM
โDec-10-2019 05:56 PM
โNov-29-2019 05:20 PM
โNov-29-2019 10:26 AM
โNov-28-2019 11:01 AM
Matt_Colie wrote:GREAT POST I HAVE SEEN THE INSIDE OF MOTORS THAT HAVE BEEN NOT TAKEN CAR OF..THEY ARE ALL IN A JUNK YARD
OK, Here comes a clear answer for those still reading the thread.
Most engine oil is composed of three different elements:
The actual lubricating oil and added components -like viscosity managers.
Anti-wear additives - ZDDP used to be prime, but now others.
Anti-corrosives - to combat the effects of combustion by products.
Now, Oil does not wear out. If it is largely viscosity managers (What makes XWXX work) those may show some shear-down in use. That is less of an issue with modern oils and engines (why they can live with 0WXX).
The anti-wear additives are prone to oxidation. They are fine in the can, but once exposed to air and combustion by products, they start to get damaged.
The anti-corrosives are there just to deal with the combustion by products that leak past the rings. This stuff is nasty. Left alone, it could rot out a stainless pot. That is the first part of an engine's lubricating oil to be damaged. When that component gets killed, then things go bad in a big hurry.
The last two above are why Mobil with the famous Mobil1 line still pitches annual lube oil changes as a minimum.
What do capital engines (like ships and such) with huge lube oil tanks do? We regularly send samples for analysis and get back information as to what to add to the lubricating oil to keep it in spec. Many actually have chemical treatment systems (sort of like a water softener, but different) to remove chemical contaminates.
Now, that said, if you like your engine and plan (hope) to keep it a long time, change the oil. Learn to do it yourself and buy the lube oil in big jugs and snicker at those that don't know what you now know.
What is this guy???
He was a ship's engineer for a lot of this life, and then came ashore to work and run Detroit engine laboratories until I retired.
Matt
โNov-24-2019 03:19 PM
โNov-24-2019 08:06 AM
โNov-24-2019 05:05 AM
โNov-24-2019 04:51 AM
โNov-24-2019 04:13 AM
โNov-23-2019 10:03 PM
โNov-23-2019 03:35 PM
โNov-23-2019 03:18 PM
Terryallan wrote:K Charles wrote:
Condensation is not a rumor. Once you take the oil out of the bottle the moisture in the air gets in it.
Just a question mind you. IF the oil is sealed in the engine, with no leaks, and no way to get air in. Does it still condensate?
โNov-23-2019 02:07 PM
carringb wrote:I so agree i take mine for a drive once a month and run the geni. too.. make sure to put some kind of fuel stabelizer in it and fill the fuel tank all the way. JMO and letting it set so long without driving can sez up ihe brake calapers too..sorry about the spelling
FWIW - here is Ford's official policy for long-term storage for the E-series:
โข Change the engine oil and filter prior to storage because used engine oil contains contaminates which may cause engine damage.
โข Start the engine every 15 days for a minimum of 15 minutes. Run at fast idle with the climate controls set to defrost until the engine reaches normal operating temperature.
โข With your foot on the brake, shift through all the gears while the engine is running.
โข We recommend that you change the engine oil before you use your vehicle again.
That said... I know many folks with V10s that do nothing special for the engine. The generator is the neediest component on the RV, and probably does need special attention to ensure it starts back up.
โNov-23-2019 01:38 PM
