Raise door, or install low profile A/C? Freelander 19CB
bglz42
Hi!
I just took deliver of a '14 Freelander 19CB. Loving it so far, BTW...
It came with a Dometic Brisk II 13,500BTU a/c unit. It puts me at 10'10" tall as the highest part of my MH. My 30x50 pole barn has a door height of 10'6". Once clear of the door, the rafters are 11'.
I am trying to decide which to do, modify the door or replace the unit? Would consider the Dometic Penguin or the Coleman Mach 8.
Modding the door would consist of lifting the door off the tracks, (it's a 12' slider), cutting the header then bracing it and replacing the tracks.
The existing A/C seems like a good one, and the low profile replacement would be more expensive. Are the ones listed good units?
Thanks in advance!
Jim in Texas
2014 Freelander 19CB
20 REPLIES 20
Bordercollie
I thought of erecting a slightly taller shelter tent structure for the rig and saving the garage for storage or work space. But your solution is probably more practical and better looking.
ron_dittmer
If you decide to change out the a/c unit, I hear the Coleman Mach 8 runs notably more quiet compared to the Dometic.
Our motor home is low profile, ductless to achieve the 9'-10" tippy-top height to the a/c unit. Our low profile Dometic fan is noisy. Some PC owners special order the Mach 8 for less noise. I don't know the cost penalty for it, nor have I personally compared the two. I assume what I read to be true.
Oh, I just now seen that you bought the Mach 8 🙂 and all is well.
bglz42
LOL! Love it!
Actually, where I come from we would have said, "Hold my beer and watch this!"... and got a runnin' start!!
I decided to be a kinder, gentler Texan! LOL!
Jim
tboss
Glad you solved the problem but where I come from we wld have took the unit off the camper,sold it ,put a big sheet of 3/8 plywood over the hole and installed a window unit, and there problem solved..just my opinion..where am I from Oakdale Ga.
bglz42
Well, I bought the Coleman Mach 8 and had it installed. It bought me 5 inches, works like a champ and fits in the barn!
Bordercollie
Raise the whole barn and add some to the door??. Park outside like most us and watch stickers fade.
pnichols
If you do decide to change to a low profile A/C, you may want to also consider one of the high efficiency ones that are low profile.
The 13,500 BTU high efficiency units require less current to both start up and run - so they may run fine on only a Honda 2000i potable generator. Your stock high profile standard efficiency 13,500 BTU A/C probably can't be run on a Honda 2000i.
2005 E450 Itasca 24V Class C
DaHose
You don't have airbags, do you?
Jose
bglz42
Thanks for the advice, Teachers Pet! But an 8" reduction in my floor would be a pond! I am on the coastal plain at about 7' elevation. My house is raised but the barn is at grade. first rain and it would flood. I am very close now I think...
Oh and no sweat on the header. It would be sandwiched on the backside with a 2 by 12...
bglz42
LOL! The thought crossed my mind!
I scraped the approach down a bit with my loader... now I am lacking an inch or two! Where there is a will...
Teacher_s_Pet
Cut the floor down 8" and taper 20' back to original floor level with a 2" "C" channel in the sides of the cut down at the door opening, to drop in a panel under the door to keep vermin out. I have seen this done about a half dozen times. I would really be concerned about cutting any header "Unless" in the gable end. If that is the case the header is basically a mounting surface and might be able to be raised to the height of the bottom cord of the rafter. Check with the builder for any loading on the header. Plus you will have to rebuild the slider if you raise the header to give the 10'10" or 11' opening you need. This from a guy that sold garage doors to pole builders & pole building distributors, 1st as a garage door dealer and a factory sales rep for 25 years,
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
hotbyte
Bummer...recall reading your excitement over the new rig. I'm in the raise the door camp unless dealer can work good deal for trading in current ac.
I have one of those aluminum carport shed things for boat. When we got the bay boat in signature, discovered the windshield/grab bar were too tall. Luckily, the boat has optional quick removal windshield/grab bar so I remove it before backing in. A pain but doable.
bglz42 wrote:
Mich, I actually drove it in right up to the ac unit...
If you approach with enough speed, the ac won't be an issue any longer 🙂
2018 Minnie Winnie 24M
Mich_F
Oh well, at least now you're definitely sure of how high it is. I wonder if you could you let enough air out of the tires to make it through the opening, although 4" is quite a difference. You might also be able to gain a little by removing the AC shroud/cover.
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
bglz42
