rear camera delay
T_bone1
on my rv I have the three camera monitor system...When I use a turn signal and it cancels it takes about 15 seconds for the view to return to the rear camera..i have checked the menu and diddled with the signal delay but made no positive headway..The brand is rvs systems.
2017 Georgetown 329S
2015 Toyota Tacoma toad
10 REPLIES 10
T_bone1
Go to menu .select trigger delay.3-4 seconds
KansasRV
How did you adjust the delay?
T_bone1
I adjusted delay.much better
bullydogs1
The two motorhomes I have owned including this one delay about 5 seconds...I pass, wait until the toad clears, then put right signal back on to get back in...
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
T_bone1
Main inconvenience is when passing..I use rear view to see when I am past the passed vehicle..
K_Charles
T bone wrote:
I have been on the website and the manual does not address this problem.
some might think there is no problem to address.
Ours is the same way
T_bone1
LadyRVer
The camera on my former motor home did the same thing. A friend said theirs was the same way.
Sorry, double post. Edited by Barb.
LadyRVer
rgatijnet1
Try this website to find your manual and see what it says about the delay. RVS camera systems
My Voyager system has a menu setting to adjust the delay time. Don't know about RVS system so you need to check what the manual says.
