Recommendations RV Repair electrical/inverter NC
Discovery8
I'm looking for recommendations for a RV repair shop/mobile unit that is knowledgeable with the electrical system and inverter for a Class A DP in the Raleigh-Durham NC area/surrounding areas or other states (Virginia, Maryland, etc.) Thanks.
7 REPLIES 7
PastorCharlie
Techmaster Marine is the Magnum inverter service tech for the east cost of the US and he is located in Washington, NC. His service area is from FL to MD. 858-204-8878. Nice person.
ferndaleflyer
I ran my DP Winnebago for several years with the inverter sitting at home. I made a jumper from the hot side of the chassis batteries to the hot side of the deep cycle house batteries and they would charge while going down the road. If they became depleted while sitting I had a charger that I hooked up to replenish them......worked for me as I was to lazy to reinstall the inverter after having it repaired the 2nd time
Discovery8
ferndaleflyer wrote:
There used to be a guy around Denton that was a factory rep for Xantrax inverters-----I have his info at home if you don't find anything. Also a good repair place near Colridge, NC I also have that info at home.......
Thanks. My problem is bigger than I thought. Either the alternator or voltage regulator or both are not working and need repaired/replaced and the inverter needs to be repaired. I cannot find any mobile repair that can help me and the RV shops are booked out for a couple of months. I have an external battery charger keeping the batteries charged.
wallynm
RV Service Reviews
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
ferndaleflyer
bullydogs1
There is also a Camping World in Clayton but I wouldn't go there..Mario's is fine and if you were a bit east towards Rocky Mount there is someone. Your inverter might need a new board and in that case you would have to call the manufacturer of that inverter to find a place that can do that.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
amxpress
1) Marioโ€™s RV Repair @ 919-210-9695
2) Jim Baker @ 919-946-8103
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
