โFeb-04-2017 09:19 PM
โFeb-19-2017 01:00 PM
โFeb-19-2017 12:32 PM
โFeb-05-2017 08:48 PM
โFeb-05-2017 08:47 PM
โFeb-05-2017 09:18 AM
Dale.Traveling wrote:
Easy project. The hardest part is finding a ready made tank to fit the space the black tank has. Probably the simplest way to transfer water would be using a portable pump when needed. And also use the pump to fill the tank. If you find one with the same foot print it would also be a back up to the primary. Just try and stay with a tank of the same water volume as the original black tank for weight considerations.
An alternative to consider would be to just leave the tank in place, seal the opening for original toilet and cross connect the two waste tanks increasing the gray water holding capacity. Easy enough to carry extra water externally while dumping, even gray water, anywhere other than at an approved facility can get you into trouble.
As far as when the day comes to sell the modified coach I wouldn't worry as long as you're considering do the mod to the 1992 Pace Arrow in your forum signature. Now if the coach was a 2012 may not the best idea considering your target buying audience would be a pretty small focus group.
โFeb-05-2017 08:46 AM
โFeb-05-2017 08:20 AM
Toddupton wrote:
Also not sure about adding more water capacity than holding tank capacity. If you have 100 gallons of water but only 50 gallons of storage in the gray then what can you do with the other 50 gallons? You would have to dump it to keep using your other 50 or use the outside shower a lot.
โFeb-05-2017 07:08 AM
โFeb-05-2017 07:06 AM
โFeb-05-2017 06:38 AM
โFeb-05-2017 06:08 AM
โFeb-05-2017 05:51 AM
Clamrobot wrote:
I will find out if my sink goes to BW tank. Yes, I have used a composting toilet for about 3.5 months up in alaska,it worked just fine as long as you divert the urine into a separate container. Used with one other person it for 1.5 months before having to empty it. The waste just comes out looking/smelling of dirt.
โFeb-05-2017 05:07 AM
Clamrobot wrote:
Dale. Traveling - I was also considering keeping it as a secondary grey tank, and you're right, it's easy to carry extra fresh water elsewhere in the coach. What was it you meant about the modification, and a forum signature? I am also quite new to the forum format,and that one may have gone over my head ๐
โFeb-05-2017 04:20 AM
