โOct-06-2013 10:42 AM
โOct-10-2013 12:33 PM
RayChez wrote:
Zmotorsports, that is a great post on what you have done to your last three coaches. I really enjoyed reading your post and all the work you have put into your coaches. Your Dynasty looks nice on the signature picture.
โOct-10-2013 11:35 AM
Deano56 wrote:I'll bet that filon, expecally considering the age of the coach (1990)!mike brez wrote:side are fiberglass panels, the matting under the gelcoat can show through after years,Deano56 wrote:
. Either way I will be doing extensive sanding to get it free of the matting showing throughh on the side panels.
Are the sides Filon?
โOct-10-2013 10:19 AM
โOct-10-2013 06:02 AM
โOct-09-2013 02:41 PM
โOct-09-2013 01:24 PM
โOct-07-2013 05:40 AM
Deano56 wrote:
I have a 1990 Champion LaSalle, there is no clear coat on this model, it is metal on the bottom and fiberglass up to the roof line, near chalky and has lost most of its shine.If I were to put an applied gloss it would be an automotive clear coat which I don't plan on doing unless this is way more time consuming. Either way I will be doing extensive sanding to get it free of the matting showing throughh on the side panels.
โOct-06-2013 07:09 PM
โOct-06-2013 06:24 PM
wny_pat wrote:wirenutz wrote:You guys are talking two different finishes. Gelcoat and Clear Coat are different!!!Rascally Road Warrior wrote:
You should consider using or buying a rotary polisher. You could probably get a cheap one at Harbor Freight for under $50. They also sell the wool pads that you'll need to do the job. I an going to assume that this is a gelcoat finish.
Order some Presta Super Cut Compound (Google it) and go to work. Follow through with some Meguiars #105 with your orbital and a yellow cutting pad. The Presta has a 600 cutting grit and the Meg's has a 1200 cutting grit which finishes to a mirror shine. We rarely ever wet sand going this route and our customers are wowed by the results.
would this method work even if the clear coat is completely wore off ?
โOct-06-2013 06:19 PM
โOct-06-2013 04:27 PM
popeye766 wrote:link?
Check out my posts on painting my pace arrow a few months ago.....
โOct-06-2013 04:24 PM
mike brez wrote:side are fiberglass panels, the matting under the gelcoat can show through after years, it's not like a boat where it has heavy gel coating on topDeano56 wrote:
โOct-06-2013 04:21 PM
Rascally Road Warrior wrote:I am fully equipped with polisher (Bosch vari. speed), pads, 3m compounds and anything thats needed to do the job. Now all I need is the time.
โOct-06-2013 02:42 PM
