Running AC while parked in Carport?
supercub
My motorhome is stored in a covered carport. There's about 20" or so between the roof and the AC units. The sides and ends of the carport are open. Is there any problems with running the AC's while parked in the carport? Thanks
Brian
5 REPLIES 5
MRUSA
You have no problem. I run my AC in a garage with only the garage door open and the only problem is that it makes the garage hot.
Marc, Wellington FL
2013 Entegra Anthem 44SL
2018 Lincoln MKX toad
EEZ-RV tire pressure monitor
supercub
It will be running on generator power..and no problem with ventilation for the generator either, it's totally open in that area.
Chuck_Gail
As long as the VOLTAGE INSIDE the RV with the A/C running is at least 110 VAC, no problem. If under that voltage, your A/C is at risk.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
wildtoad
Sounds like you have plenty of air so have at it.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
sch911
No
OEM Auto Engineer- Embedded Software Team
