โJun-23-2018 07:53 AM
โJun-24-2018 02:16 PM
Gdlow wrote:
My running lights at the top of the MH in front are not working. The ones in the back do. I can't locate a fuse specifically listed for that. Any suggestions on the reason? :h
โJun-24-2018 11:13 AM
โJun-24-2018 09:16 AM
BigSkyBob wrote:
Gary, the front and rear clearance lights, the side marker lights if you have them, and the headlights are probably on the same circuit. Have you tried the headlights? If so, there will be a fuse for the above in the compartment with all the other 12 VDC circuits. That's where I'd start.
โJun-24-2018 05:12 AM
โJun-23-2018 10:23 AM
wildmanbaker wrote:
Gary, your front and rear marker lights should be on the same circuit from the headlight switch. I would start at the front marker lights and see if you have 12 volts to the lights themselves. Use jumper cables or a line from the battery ground terminal to verify power. If you have not power to them, start trying to trace the wiring down by going behind the TV, as not many manufactures insulate the front caps very well, and you may be able to see/trace the wire from there. It probably runs down the drivers side pillar to the switch. You have a large RV dealer in your town. If you go to the service department and explain what you have and are trying to do, they may be able to give you a print-out of the wiring for you MH.
โJun-23-2018 09:38 AM
โJun-23-2018 08:42 AM
Dutch_12078 wrote:
Might be a bad ground...
โJun-23-2018 08:29 AM
