Schwintek slides
Semi_Retired_Gr
2013 Tiffin 30GA. 15k miles - immaculately maintained. In Arizona Feb.-March. When retracting the front slide the rear portion of the slide (the kitchen) stopped and the slide was skewed. Stopped - extended - and tried again. Same thing. Multiple times. Looked online and found the slide could be manually controlled. Retracted. Took the MH to the dealer - now 3+ weeks later they have photos of the floor where the slide roller has indented the subfloor approximately 1/4". Therefore the slide binds and the rear motor stops. Tech convinced the rear portion is too heavy for the support system therefore indenting the floor - BTW - front floor shows no indentation. As a design engineer seems obvious to me. Tech has asked Tiffin for support - so far not responsive. Sent photos Thursday evening and hoped to have a better resolution today - so far no response. Seems a Tiffin design/build problem. Hope they'll stand behind their product. Will post as soon as we get their response.
Gary & Liesel
Cocoa, our Chocolate Lab companion
2013 Tiffin 30 GA
2004 Honda Element Toad
21 REPLIES 21
katoomer
We too have a very heavy kitchen slide. It failed one time. We had to disconnect the main shaft from motor
and then it took 3/ 220 lb men to manually push it in
2009 Newmar Ventana 3942
2010 Pace Shadow 18ft
2010 KTM 450 XCW six days
2010 Can Am Outlander 650 XT
2014 Can Am Outlander 500
2007 Yamaha YZ250F
1989 Douglas Skater 21' Twin 2.5s
streamcamper
Wow. Instead of driving with the slide out to a hill, could you have tilted the coach with the levelers to achieve the same advantage?
fivejackie
We have this happening with our Hurricane 27k. Its comes in ok when empty. When the RV is loaded I have to pull on it while my wife works the switch. The last time we couldn't get it in this way. So we loaded up and dropped the jacks. I drove out of our site on to the road. I drove up on a side of a hill. With the help of my pulling and gravity, we got it in.
Don and Jackie
2115 Hurricane 27K
2113 Redhawk
1992 Pace Arrow
kjburns
Yours work? Both of our living room slides have failed on a 2015 HR Vacationer. We're under warranty so I think we're okay.
2019 Dynamax Isata3 24FW
newman_fulltime
Its not just on tiffans I have seen it on redwoods and others the redwood used a sheet of aluminum to fix the floor
Semi_Retired_Gr
newman fulltimer wrote:
Why not put more rollers to divide the weight
Seems an obvious solution. Techs and I agree. Wished Tiffin had considered it during design/build. Of course now we have to address the floor indentation.
Gary & Liesel
2013 Tiffin 30 GA
newman_fulltime
