Feb-09-2014 11:01 AM
Feb-10-2014 06:40 AM
Feb-10-2014 02:59 AM
donsuefuggrwe wrote:You can scrap the tape off using a heat gun and plastic scraper just the same as caulk. A bit harder since Eternabond does harden like caulk which is the advantage with of the tape rather than caulk. Once taped it's sealed for the like of the roof.
If you cannot get the eternabond tape off what do you do when it is necessary to replace a skylight or holding tank vent or fridge vent etc.
Feb-09-2014 09:09 PM
John&Joey wrote:
It's up to you, but all of the above is overkill. Since you're FT'ing ask around in the park to see what others do, not just the internet.
I think you'll find most simply scrub the old caulk clean (brush, dish soap, water, let dry) then maybe even clean it up a tad more with mineral spirits (JUST the old caulk NOT the roof.) If they find any caulk that is lifting off the roof then that is removed with a plastic scrapper and a hair dryer.
Once that is all done then a thin coat of Dicor self leveling goes over the clean old stuff to fill in the cracks. Some skylights require a special caulk as not to become brittle and crack. You'll need to read up on what you have.
You should be good for another 5-10 years. I think most on this forum mistake yearly inspections with doing it every year. If that was really the case then I would hate to buy a new rig and expect an easy life.
Here is a good video clip of a FT'ing couple and how they do it.
Video Clicky.
Feb-09-2014 08:12 PM
Feb-09-2014 06:38 PM
Feb-09-2014 06:07 PM
doxiemom11 wrote:
Remove old caulk - put new one and then eternabond tape. You won't have to worry about it again.
Feb-09-2014 06:03 PM
Feb-09-2014 06:01 PM
Feb-09-2014 05:58 PM
Feb-09-2014 05:36 PM
Feb-09-2014 05:04 PM
magik235 wrote:
I use EternaBond roof tape and Dicor caulk.
Feb-09-2014 05:01 PM
Feb-09-2014 05:00 PM
Dale.Traveling wrote:
6" tape is pretty wide. The wider tape is a bit harder to work with and get a nice looking job. Plus it costs more. This is one of those times that 'The bigger the glob the better the job' isn't a good idea. Consider a 2" or 4" 50' roll. Extra is good to have incase you get a puncture. Keep the extra in a zip lock bag and it will last forever.
Once you stick the tape to something it's stuck. No pulling it up and starting over and it you somehow get it stuck to it's self there's no recovery. If you look at my images that is 2" tape. Easy to work with and gives good coverage for flat over lapping surfaces.
The cleaner and roller you can probably pass on. A quick wipe with acetone followed by a shot of Windex will give you a good clean surface. I have a roller and my thumb does a just as good of a job.
Take your time getting the tape down. Watch the various You Tube videos for the tricks to make the job easier. Go slow so you don't get air bobbles since a bobble is impossible to get out. Any job longer than 12 inches draw a reference line to keep the tape going in the right direction.
Good luck.
Feb-09-2014 04:47 PM
