My furnace started acting up to where the fan runs for a few seconds, but will not ignite.
Now I realize that it could be several things wrong that would cause that such as the board, sail switch and overload module.
What I want to know is how do I pull this furnace out to test it on a work bench. Does it come out through the outside or inside. It seems like there are several ducts attached to the furnace which are almost impossible to get to IF I have to disconnect them or do they stay attached and you just pull out the inside part.
Any advise is appreciated.
RayChez
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
