May-21-2021 07:54 AM
May-27-2021 12:32 PM
May-23-2021 02:27 PM
May-23-2021 07:10 AM
May-23-2021 06:20 AM
ksg5000 wrote:
The cost of new unit maybe less than repair - make a phone call to repair shop to determine.
May-22-2021 04:55 AM
May-21-2021 06:45 PM
grldst wrote:
Easy fix and a heck of a lot cheaper then buying a new one. I replaced mine some yrs back, don't remember the exact procedure, but I do remember I did NOT have to remove the microwave, and it was not difficult.
My foggy mind seems to recall that you remove the facial plate around the door and you will get access to the bolts/screws to remove the door.
You should be able to google for parts, and you tube may even have a video on the repair.
ON EDIT: My memory has recollected that when the facial is removed you will see the door latch workings. The door does not have to be removed. Its a cheap plastic latch that breaks. I tried glueing it and it didn't last long, so I just replaced it. Like I stated earlier, the parts are cheap, the fix easy.
May-21-2021 01:43 PM
May-21-2021 12:50 PM
May-21-2021 10:39 AM
DarkSkySeeker wrote:It is a convection microwave, I had it running on the preheat setting.
>> preheating it so there is no food stuck inside
You were running it empty?
May-21-2021 09:23 AM
May-21-2021 09:11 AM
May-21-2021 09:06 AM
May-21-2021 08:54 AM
May-21-2021 08:50 AM
