Side Cameras
Ole_B
I have a 2016 Newmar ventana. I do not like the side cameras and prefer to see the towed vehicle when making a turn. Is there a way to disable the side cameras without pulling wires from the back? I have a voyager system. Thanks to all
31 REPLIES 31
rgatijnet1
usersmanual wrote:
then stay on topic.The op asked about how to disable his side view cameras>>
He got the answer. What have you provided to this topic? :?
usersmanual
:B
rgatijnet1
Effy wrote:
usersmanual wrote:
Two Hands wrote:
I would think more before disabling the side cameras. I use my mirrors to watch the toad during turns. The side cameras make it much safer and easier to see vehicles coming up on either side of you.
the guy asked about how to disable them not what our opinion of such was?? geez you guys go off topic so easy
I've been watching your posts and you rarely have little to offer to the conversation other than criticism and snide remarks. You've been on here for less than 3 months and all you seem to manage to do is irritate people. If you don't like the forum - or people in general for that matter - go away. This is not the place for you to compensate for a lack of whatever you are missing in your personal life to come here and troll people to feel better about yourself.
X2
Effy
2013 ACE 29.2
rgatijnet1
As I mentioned earlier, on the Voyager system, you can disable your cameras with the menu. Just hit MENU-INPUT then you scroll down to the camera that you want to disable. Once you find that camera, which will probably be cameras 2&3, then you just change the MIRROR setting to SKIP.
If you don't want to disable them completely, you can pick SPLIT SCREEN and have the benefits of both your side camera and rear camera on the monitor at the same time when you use the turn signals.
IF you do not want to go through the MENU way of doing this, the Voyager monitor pops right out of the dash without any tools. Then all you need to do is unplug the cables coming in to the back of the monitor labeled cameras 2&3. Snap the monitor back in the dash and you are good to go. If you disconnect the cameras, I would tape them off so that the next owner can decide if he wants them or not.
Bruce_Brown
Moderator
Moderator
Add me to the list that finds them to be useless 99% of the time and agree with the OP 100% on this one.
I've looked through my menu, checked the book, tried some other stuff and I can't figure out how to disable the darn turn camera.
I like my mirrors.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
DSDP_Don
I dislike the side cameras too! I think they're useless! I'm guessing the OP is having issues with lane changes on the highway, not while making low speed turns in town.
When I change lanes, I want to see when my toad clears the vehicle I'm passing. That can't be done by the side cameras because you can't get any depth perception. The only time I find them of any value is maybe once a year to look down the side of the coach when backing in. Even then I have to put the coach in neutral and the turn signal on.
If you have a good set of mirrors, which means a main mirror and convex mirror on each side, you shouldn't have any issues with safely changing lanes.
With all that said, I agree with "Mr.Mark", don't disconnect them, just learn to drive without them. I give a quick turn signal and then turn them off while making my lane change. In town during slow speed turns, leaving the turn signal on really doesn't matter.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
usersmanual
J-Rooster
Ole, any questions can be answered by RVCams.com Tim Lazaroe is the owner and he is very helpful to people on RV.Net. Tim sells those systems.
Mr_Mark1
Ole B wrote:
I have a 2009 chev malibu. When I am turning I prefer to watch the mirrors and then check the back camera to make sure the car clears all curbs, as when turning I can see the tires closest to the curb or object.
I would think if you can not turn off the 'camera feature', just turn on the turning signal just as you start the turn then turn it off.
Obviously, you need to do what is comfortable to you.
I can't see the curbs so much out of of the rear camera, mainly, just the full view of the tow vehicle. I can get a much clearer view by watching my side mirrors. I use the side view camera's as an extra set of 'eyes' along the side.
Since our toad is so much narrower than the coach, curbs would not be a problem. I would be hitting the curb with my coach first before the toad even thinks about it. LOL!
But, I understand what you want and I would think there is something that you can flip or unwire to turn off the side camera's.
Good luck,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
Ole_B
Effy
You can turn them off via the menu. Or rather change the triggers to all point to the central cam. I disabled mine. I didn't like having to look at the center of the dash instead of keeping my eyes up an to my mirrors. I can also see my toad better with central only.
2013 ACE 29.2
jorbill2or
I assume the Op wants to turn on his turn signs and still see the rear view in his monitor not have it automatically switch to the side view camera.
Personally I wouldn't do this as there is nothing to see in the std rear view other than the front of the toad. That said wouldn't disconnecting the turn signal wires to the system accomplish that? don't disconnect the Cameras themselves . That stops the automatic transfer of the monitor to the side cameras and still leaves them avail via the monitor controls. The system I have can't be disabled if the turn signals are wired into the loop.
Bill
Mr_Mark1
I, too, would think that once you are making your turn, you will see the toad better in the mirrors vs. the rear camera.
When I first start off in the mornings, I check that the tires are rolling on the Honda when I make my first turn through the side mirrors (usually when pulling out of the RV site). You can't see the tires through the rear camera.
What are you wanting to see through the rear camera that is more important than the side camera and side view mirrors? The toad is going to follow you no matter what.
You don't have your toad listed in your signature so if you have an unusual set-up, we are wondering.
Just curious.
Safe travels,
MM.
Mr.Mark
rgatijnet1
I have a Voyager three camera system and by going through the "menu" on the monitor I believe that you can disable any of the cameras. My side cameras ONLY come on when I turn on the turn signals. Until then, the ONLY thing I see on my monitor is the rear camera view.
