Soft floor. A lot worse than thought!!
Wikid86
2008 Holiday Rambler . Bought back in march from a dealer here in Fort Worth. The floor was a little soft between the shower and toilet. Salesman said it wasn't bad and the leak had been fixed. I had planned to fix it this winter after camper season.
Fast forward to August and the floor has gotten worse and i located the REAL leak under the shower. I started taking it out last night and discovered its all under the shower, infront of shower, and down wall next to bed.
After pulling ply board out last night I discovered it has 1 1/4 inch of styrofoam under the ply board. Then under that has 1/8 inch or so ply board. The aluminum joist are about 32 inches apart.
What all should I replace? Do I replace the styrofoam? How about the ply board under the styrofoam? How would I even get to that?
I guess I'm going to take the shower and wall out and replace all that wood too....
Wow this turned REALLY BAD Quick!!!
2008 Holiday Rambler Atlantis SE 128 (class C)
2012 Dutchman Sport Travel Trailer
2006 Custom Built Tear Drop Camper
2005 Rockwood Popup Tent camper
Yes, I'm not RV poor by any means...
20 REPLIES 20
ADAD437
Why don't you throw it back on the dealer or did you buy it as is?
James,Gail & Pancho
2005 georgie boy Pursuit
๐Ÿ˜›
Wikid86
hotbyte wrote:
One thing you might consider is when you replace the skirting board that is under the shower is to make it removable so you can open it up and inspect under the shower. I've thought about making mine removable just so I can check under there every so often to be sure nothing is leaking. Right now I have no reason to think it is but you never know!
I thought about adding a galvanized pan with a drain tube as well...
But you're right that wouldn't be a bad idea. I'm still unsure how ill match up the back wall of the shower if I remove the wall. I rent this motorhome out on the side and have a rental contract for 8/28 (18 days away). So I need to fix'er up quick!
Snowman9000
Before you go nuts on it, go to http://www.rotdoctor.com/products/cpes.html and read everything.
I used CPES on a wood rot repair. It is great stuff. If you can get to the wood and it still is intact, CPES can save you tons of work. CPES soaks into dry wood like crazy, then makes it very strong. If the wood is weak but still retaining its shape, you can use CPES and then a thin epoxy he sells, to coat it.
Currently RV-less but not done yet.
hotbyte
2018 Minnie Winnie 24M
Wikid86
Francesca Knowles wrote:
Well, you've solved the two main problems:
You've found the true source of the water (and stopped it?) and you've removed the vinyl that's preventing the underlayment from drying out. Some of that wood may well dry out undamaged except for water stains- you may not have to tear out as much as you think. I'd let it get well dry and then assess what actually has to be torn out.
One caveat:
To prevent mold growth, I'd saturate the wet areas with a strong bleach solution while they're still wet. Doing that to wet wood will help to evenly distribute the bleach throughout.
Yes the leak was the 1st threaded joint under the drain. It wal literally pouring out Tuesday. It had never before ran out in the main floor.
Now you say about letting dry out I might give that a shot. I wish I'd put a fan on it last night.... I'm a big DIY'er. But thinking of pulling the shower wall scared me last night thinking of doing it myself. I called my neighborhood handyman that's helped me renovate my current house project. He's going to help me pull the shower and wall tonight. I might hold back on cuttin all th way down the bed side. I'm betting that will dry and with bleach should only be water stains
Thoughts on type of flooring to put back in? I was thinking of the peal and stick premium laminate squares???
Francesca_Knowl
One caveat:
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
