โAug-14-2013 03:33 PM
โAug-15-2013 10:24 PM
โAug-15-2013 08:21 PM
Big Katuna wrote:dougrainer wrote:
He has the Intellitec system and when on 30 amp will NOT allow power to the REAR AC. Your INVERTER is NOT showing 30 amp. Your EMS panel is showing 30 amp. Doug
True, but not accurate. When my Intellitec is connected to 30a via an adapter I can run both ACs. When I was missing one leg because my 50a cord was hosed, the EMS still
showed 30 a on the panel but the 2nd (rear AC) would not work.
My thinking is that if you are plugged into 50a service improperly wired to two legs of the same phase, Inteelitec would show 30 and both ACs would work.
Please let us know what u find.
โAug-15-2013 06:13 PM
โAug-15-2013 06:02 PM
Bud
USAF Retired
Pace Arrow
โAug-15-2013 04:31 PM
vegasfoodguy wrote:dougrainer wrote:vegasfoodguy wrote:
I didn't want to hijack the other thread running on transfer switch. 1999 Monaco Diplomat. The inverter shows 30 amps when connected to 50 amps.
I have zone 1 and zone 2 on thermostat.
I should be able to run both air conditioners at the same time, right now I can't.
Zone 1 is the FRONT AC. Zone 2 is the Bedroom AC. Do BOTH work individually? Or does ONLY 1 work at all on Shore Power? What happens when you run the Genset? 1999 DIPLOMAT. Do you have the LP Genset? Doug
Doug, When zone 1 is selected, front air is on, when zone 2, rear on, same shore or genset, yes i do have propane genset. As an aside, when front air is on fan runs on rear air, and vice versa.
โAug-15-2013 03:04 PM
โAug-15-2013 07:07 AM
โAug-15-2013 04:50 AM
โAug-15-2013 04:47 AM
Doug, The panel i'm referring to, is just above the passenger seat, it has the switch to open the slide and a couple of meters, shows the battery charge level.
When connected to the pedestal we did verify 2 120 volt circuts.
Thanks all for your help.
Terry
โAug-14-2013 06:58 PM
โAug-14-2013 06:42 PM
Bud
USAF Retired
Pace Arrow
โAug-14-2013 05:32 PM
โAug-14-2013 04:58 PM
โAug-14-2013 04:14 PM
