Maybe transfer switch bad?
vegasfoodguy
I didn't want to hijack the other thread running on transfer switch. 1999 Monaco Diplomat. The inverter shows 30 amps when connected to 50 amps.
I have zone 1 and zone 2 on thermostat.
I should be able to run both air conditioners at the same time, right now I can't.
Monaco Diplomat, Cummins, 38a
Toad Grand Cherokee and Jeep Wrangler, Brake Buddy.
16 REPLIES 16
conmoto
I just went through a similar situation and I believe it was because the house batteries were low, I had it away for 10 days getting service done. It made the EMS act goofy and read 30 instead of 50 amp at my rock solid house pedestal. ACs would not run etc.All is good now with full charge.
vegasfoodguy
Big Katuna wrote:
dougrainer wrote:
He has the Intellitec system and when on 30 amp will NOT allow power to the REAR AC. Your INVERTER is NOT showing 30 amp. Your EMS panel is showing 30 amp. Doug
True, but not accurate. When my Intellitec is connected to 30a via an adapter I can run both ACs. When I was missing one leg because my 50a cord was hosed, the EMS still
showed 30 a on the panel but the 2nd (rear AC) would not work.
My thinking is that if you are plugged into 50a service improperly wired to two legs of the same phase, Inteelitec would show 30 and both ACs would work.
Please let us know what u find.
Will let you know, Will work on it this weekend.
Big_Katuna
My Kharma ran over my Dogma.
enblethen
Have you verified that the shore power is 120/240 and not 120/120 neutral?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Zone 1 is the FRONT AC. Zone 2 is the Bedroom AC. Do BOTH work individually? Or does ONLY 1 work at all on Shore Power? What happens when you run the Genset? 1999 DIPLOMAT. Do you have the LP Genset? Doug
Doug, When zone 1 is selected, front air is on, when zone 2, rear on, same shore or genset, yes i do have propane genset. As an aside, when front air is on fan runs on rear air, and vice versa.
So you state when on Front air the compressor and fan runs and it cools but the rear only runs the fan and NO compressor and vice versa? If so, you must have the Intellitec EMS system that sheds the compressor ONLY IF the RV is on 30 amp service. But, on Gen set BOTH Fans and Compressors should operate. On 50 amp service, all 120 appliances will operate. Doug
vegasfoodguy
Big_Katuna
I just wet thru this. You need to take the cover off the Transfer switch and verify U have 120 on both inputs. I thought I had a bad transfer switch or EMS and all it was was a bad connection in the plug. Measuring at the pedestal is not good enough.
dougrainer
dougrainer
vegasfoodguy wrote:
Doug, The panel i'm referring to, is just above the passenger seat, it has the switch to open the slide and a couple of meters, shows the battery charge level.
When connected to the pedestal we did verify 2 120 volt circuts.
Thanks all for your help.
Terry
IF it does NOT say Intellitec on that display panel, That IS your Inverter/Charger display panel. BUT, that "30 amp" reading has NOTHING to do with WHAT and HOW you are connected to Shore Power. What that 30 amp reading is, it lets you choose what Shore Power you are ON to set the amount of 120AC amps the CHARGER section pulls in BULK(FAST) charge when you connect to Shore Power. On 50 amp you do not care that the charger will pull up to 11 amps on BULK charge. But if on 30 or 15 amp Shore power, you set it lower to free up extra amps. You are on 30 amp, you set the panel to 15 and the charger on BULK charge will pull no more than about 4 to 5 amps instead of 10 or 11. Doug
mscamping
This is true, you need to check with a volt meter and see if it reads zero between the 120 volt lines.. It will also read 120 volt from each side to ground or neutral.. It should read 240 volt across the 120 volt lines if it is a true 50 amp circuit.. Mike Mathews..
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2013 Equinox w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
enblethen
You can have two 120 volt circuits, but if they are on the same "phase" your EMS will see only 120 volts indicating 30 amp connection.
Bud
USAF Retired
Pace Arrow
vegasfoodguy
Terry
We_Cant_Wait
If you do have and Energy Management System can it be set to different AMP services i.e. 20, 30 or 50amp service? If so is it by chance set to the 30amp service setting?
CarlGeo
Have you confirmed the shore connection is 50 amps and not just 30 amps??
