Solar is not practical for roof top A/C units
To run two roof top units you need at about 2000 watts of solar, minimum
Each unit uses 12 amps 120vac or 1440 watts running
Unless you use the low power high efficiency polar cubs at about 10 amps each
And you only have full power during full sun
And if you run them in the evening you are on battery, lots of battery
Which has to be recharged the next day while you are trying to run the a/C some more, which means even more solar
So now you are at 3000 watts solar or more, plus batteries plus a large 4000w inverter
We have a couple of members that can run a small window a/C during the peak of the day, for solar assisting the batteries, for an afternoon cool down of the living area of a smaller RV
Even a 6 amp window unit needs 60 amps battery power into the inverter, which needs at least 800w of solar to generate it in full sun
That's about it
Now if you forget the a/c There is a lot you can do with the correct solar and battery setup
I can explain it to you.
1997 F53 Bounder 36s
