1. Get a tire loading/air pressure chart like
Michelin's2. Weigh your coach as loaded for travel. People, liquids, supplies, clothing, all of it.
3. Adjust tire pressures according to actual weights.
4. Test drive it. OK = Done
5. Not OK = check weight distribution front to rear. Try to get at least 1/3 of total scale weight onto the front axle.
6. Test drive it. OK = Done
7. Not OK = have front end professionally aligned to CASTER at least +5* Left and +5.5* Right. Camber close to 0* and Toe to 1/8" IN
8. Test drive it. OK = Done
9. Not OK = add hardware... Safe-T-Plus 140-series (silver) front stabilizer... Hellwig front and rear HD Sway Bars... SuperSteer or BlueOx or Brazzel's rear track bar...
10. Test drive it. Better be OK, this is pretty much trail's end.
