Storage compartments in Class C
threedogmom
I hope this is ok to ask here. We have looked at quite a few Class C motorhomes recently. One that we like has almost no storage underneath. Are there any good, reliable Class C motorhomes with a decent amount of storage? If so, what make & model?
Thanks!
20 REPLIES 20
Greydennyhawk
Our Jayco greyhawk 31ss has a great deal of storagen the basement also.
Denny, Rosie and Josie the Beagle
2016 Allegro 36 LA
2016 Mazda 3
OldRadios
Just picked up a new to us Fleetwood 27' 26Q. Most 26Q layouts have a large storage compartment under the back that goes all the way across. Ours has three hatches. The floor of it is a series of small tables with compartments under them also. This storage area was one of the things that made us decide on this layout.
2006 Fleetwood 26Q
2010 Harley Softail Toad
2015 Ford Focus Toad
Upstate (the other) New York
Handbasket
Bear in mind that weight may be the limit on some C's, especially ones with longer rear overhangs. There may be plenty of volume, but rear axle or total allowable weights may keep you from using all of it. Even some short RV's are weight-challenged.
Jim, "Mirror, mirror on the wall, what the flamin' heck happened?"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
GENECOP
Check out the Nexus Ghost...more a Super C but good storage for sure...
jhlady
Threedogmom,
Generally the longer the Class C the more storage. I have a 23C with almost no under storage and now wished I had more. Not sure if one brand will have more over another, but if you need more storage make sure you get it sooner rather than sorry later.
Hope this helps.
John
mlts22
This varies quite immensely. For example, I've been looking at shorter, 21-24 foot models. Usually they will have a corner queen bed. This means that under the bed is a fairly large chunk of storage, likely accessible from curb side, perhaps the back. Some might have a little bit of storage extend to the road side.
In general, the longer the "C", the more storage is generally available. If it is on a Sprinter chassis, in general, expect less storage than an E-350/E-450 chassis.
