Aug-15-2020 01:58 PM
Aug-22-2020 01:45 PM
DrewE wrote:
Everything else being equal, a wider tire will reduce gas mileage, not increase it; the wider tire has greater rolling resistance (and greater traction due to a larger contact patch), and also a greater rotational inertia that takes more energy to speed up and slow down. For smallish changes in tire size, the differences are small, and other factors can also come into play such as the composition of the rubber and often the overall diameter of the tire.
There are good reasons why you don't see anything other than skinny tires on Tour de France bicycles.
Aug-22-2020 12:27 AM
Aug-21-2020 09:15 PM
Aug-21-2020 08:45 PM
pianotuna wrote:
new 235/85R16 tires which will give me 1.25 inches more height; essentially they will lower the 4:56 to some other number which makes a slight difference for (better) mileage on the flat. Wider tires = lower rolling resistance = slightly better mileage. Taller tires and different side wall construction = improved ride.
Aug-20-2020 09:48 AM
Aug-20-2020 09:07 AM
Aug-20-2020 09:04 AM
Aug-20-2020 05:00 AM
pianotuna wrote:
I solved it by getting new rims (wheels) and a taller and narrower Toyo tire. That gave me more ground clearance and more tire weight capacity.
Aug-19-2020 07:56 PM
Jerseydevil wrote:pianotuna wrote:
Why are you upgrading?
Bottom line is we need more space. I have a basic starter C for 4 years now, no slides, it gets tight with two teens in tow, especially if they bring a friend along.
Aug-19-2020 05:48 PM
Jerseydevil wrote:
Looking to possibly upgrade next year so starting to research now. Since there are so many layouts and models could use some help.
Here is some of my requirements-
-Need bunkhouse- have two teens
-Able to comfortably sleep 6
-At rest stop would still like to use bedroom, restroom, pantry without sliding open
- restroom and shower seperate
- 30 foot minimum
-2010-2017 year range
What are you driving?
Aug-16-2020 12:43 PM
Aug-16-2020 09:50 AM
Aug-16-2020 09:43 AM
Aug-16-2020 08:51 AM
