Third brake light on 03 Tahoe
revump
I pull an 03 Tahoe as my toad. The third brake light above the window has quit working. Is there a fuse for that brake light somewhere?
Bob
8 REPLIES 8
Toumai
To echo what Gary said, third brake light on my 04 Tahoe stopped working. It is a sealed module with LED's. No user replaceable bulbs.
http://www.amazon.com/gp/aw/d/B000TYQB14
Dealer wanted $250. The amazon replacement I installed is side by side identical to OEM for $40 and still working 2 years later.
2009 Dutchmen Freedom Spirit 270BH
2004 Chevrolet Tahoe LT 5.3L V8
FunTwoDrv
If you determine the light itself is the problem, check out Amazon for a replacement. They are about 10% of what the dealer charges. Yeah, it's a off-shore cheapy but, the one I put in a couple of years ago is still doing its job.
Gary
rockhillmanor
If your model has it. Clean the connectors too on that bank of prongs that connect when you close the back door.
ArchHoagland
In the fuse box near the driver side door there is a fuse labled: VEH CHMSL (Vehicle Center high mounted stop lamp).
Found that info on a Google search.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
enblethen
Diagram that I looked at shows it about in the center of the under dash fuse block. Diagram says it is marked "VEH CHMSL" should be 10 amp.
It appears to be right above the 12 pin Body control module that it says is brown.
Not sure if this link will work.
Fuse block
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MountainAir05
Also check to see if the bulbs are burned out.
revump
Do you know where it is located? Thanks
Bob
enblethen
Yes, it is a separate fuse. It should be marked "CHMSL" Center High Mount Stop Light
Bud
USAF Retired
Pace Arrow
