Mar-06-2021 11:35 AM
Mar-11-2021 03:38 AM
Mar-10-2021 08:02 PM
beaubeau wrote:
First leg of trip is done. Had 10 miles of interstate, so no chance to get weighed. The plate in the cockpit says 95 for rear and 105 for front. So that’s what I went with.
By the time we got here, they were all around 118.
Does that sound okay?
Mar-10-2021 05:00 AM
Mar-10-2021 04:48 AM
Mar-09-2021 04:47 AM
olfarmer wrote:
I run what the MH manufacturer recommends on the VIN/GVWR tag. Have never had a problem. I have had each axle weighed and that had the same result for the pressure recommended.
Mar-07-2021 06:51 PM
Mar-07-2021 03:43 PM
JRscooby wrote:
Remember if you have been driving, pull in to weigh your snot, and adjust the pressure, next morning, when your tires are the same temp as outside air, you are setting on underinflated tires. Within a hour you might be setting alongside the road
Mar-07-2021 03:04 PM
Mar-07-2021 02:13 PM
Mar-07-2021 12:48 PM
Mar-07-2021 05:46 AM
beaubeau wrote:
Thanks everyone. I don’t see a way to get it weighed before I drive it, but the idea makes me want to pull into a scale pretty quickly.
Mar-07-2021 03:56 AM
Mar-07-2021 03:52 AM
Ed C wrote:
You need to know the weight...at each corner or at least each axle. Then you can check the tire manufacture's chart for those weights. If the tire pressures are right the temperature doesn't matter unless it changes drastically
Mar-06-2021 05:04 PM
