Tire Pressure Vs. Ambient
bluwtr49
I recently found that adjusting our tires to the cold inflation temperature base on the local ambient may not be the correct way to do this. Based on this info, the ambient temp for setting tire pressure is always 65F and they are than adjusted upwards base on local ambient.
This was a surprise to me and would suggest that many are running their tires under inflated.
Tire Pressue vs Ambient
Something to consider. Me, I'm going to follow this guide.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
45 REPLIES 45
Executive45
wolfe10 wrote:
the_vfox wrote:
Executive wrote:
Damn, now I've got to sit here until the temp drops to 65 degrees...gonna be a long summer I guess...:B....Dennis
Its worse for us, it has to warm up to 65 :W
NO, that is the good news in the summer.
Headed your way SOON!
How are you gonna get OUT of Texas without a BOAT.....:h....Dennis
holstein13
This is exactly the way Triptek programs their tire pressure sensors in my RV. It's based on temperature and pressure so if the temperature rises, the TPMS system calls for higher pressures in the tires. The base temperature is at 65 degrees.
I love the system because it tells me if I'm above or below the ideal pressure and I can inflate my tires at any time. I just turn to the proper tire screen and fill or release as needed. That's a huge benefit for me. I don't have to wait until morning to inflate my tires. I can inflate them first thing in the morning, at noon when the sun is shining on them or after skidding to a halt in 100 degree weather. It doesn't matter. My TPMS calculates it for me.
Once you've had the pleasure of getting the heat adjusted tire pressures, you won't want to go back to the old way of checking pressures in the morning only.
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
the_vfox
Fox and Angel, fuzz ball cat and crazy Yorkie :S
Don't call me on the weekend, Im out camping.:C
2001 Itasca Horizon DP 36LD 330 Cat and all the bells and whistles
Go Blue, US Air Force(retired)25 years ๐Ÿ™‚
Executive45
pconroy328
wolfe10 wrote:
Wow, two of us who remember our school physics/chemistry at the same time.
It's worse for me. As a Biochem major my head is filled with completely useless (and perhaps no longer valid) cr*p like Selenium deficiency and exudative diathesis. Or the carbon tracking on the Krebs cycle.
But I can't remember where I parked the car.
wolfe10
Brett Wolfe
Ex: 1997 Safari 35'
wolfe10
bluwtr49 wrote:
On the other hand, it's right on the money based on my current ambient (90F) since the pressures have risen 5 psig and it was about 65F last time I adjusted the pressures.
Yes, the ideal gas law applies. For a given rise in Temperature, there WILL be a specific rise in Pressure. PV=nRT has been around for a LONG time.
Same basic physics that prove some of the ads for Nitrogen in tires are so much bunk. Nitrogen, like other gases DOES follow the ideal gas law, not "Bubba's marketing law 101".
Brett Wolfe
Ex: 1997 Safari 35'
pconroy328
Never mind the fact that most of use pressure gauges with absolutely no idea of their accuracy or precision. While the physics may be sound, PV = nRT, it strikes me as needless hand-wringing and worrying.
"Gee, it's 72* outside, let me check the conversion chart... OK, now I'll pull out my $3 pressure gauge and check..."
wolfe10
Campfire Time wrote:
wolfe10 wrote:
Sure looks like another of those "if you read it on the Internet........" things.
And he's probably a French model too. Bonjour. ๐Ÿ˜‰
Oui, Oui. Or in Texas we would just say, Wee Wee.
Brett Wolfe
Ex: 1997 Safari 35'
rgatijnet1
I wonder why the chart DOES NOT follow it's own rule at the bottom that says:
Tire manufacturers never recommend inflating a tire to less than the specified cold inflation pressure. The bead of an RV/commercial tire can unseat
if its pressure gets too low resulting in a catastrophic tire failure. The general rule of thumb is to inflate a tire to a proportionately higher starting value when the ambient tire/temperature is hotter than 65 degrees and to the recommended Cold Inflation Pressure value at temperatures below 65
degrees F.
The chart then shows that at a recommended cold inflation pressure of 100psi, or any psi, if the temp drops to 32 degrees, it says you should inflate to less than the recommended cold inflation pressure. If it followed it's own advice, the chart would stop at 65 degrees. :R
Campfire_Time
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
fla-gypsy
This is what Maxxis says about inflation of the tires I use;
"...In order to accurately assess your tiresโ€™ inflation pressure, please note that inflation pressure should be adjusted and/or checked when the tire is cold or before driving for the day."
I call BS on the 65* baloney and adjusting for temperature.
bluwtr49
Yeh, I have my suspicions also not knowing the providence of the chart.
I'm thinking I will use the chart since I can not see any harm. For example, I will be leaving when the temps are ~104 and within 3 days be in 60F temps. Worst case, be a little high but no chance of being low.
Dick
rgatijnet1
So you want to go with an "anonymous" tire inflation chart with no idea who came up with this theory and something that is not endorsed by any tire manufacturer?
Me, I'm going to follow the tire manufacturer's charts.
