Feb-04-2014 06:21 AM
Feb-05-2014 07:10 AM
donn0128 wrote:
Look at the Firestone Transforce also. Another option that has gotten good reciews
Feb-05-2014 06:44 AM
Daveinet wrote:As per usual:topflite51 wrote:Why is that a problem? Maybe not have same level of road hazard resistance, but how often do you hit something and puncture a tire? Usually its a nail, which goes right through any steel belt, so I'm not sure the steel is buying you a lot. Nylon belted tires run cooler, so they are less likely to suffer tread separation. Nylon is going to be lighter, so it should give a better ride.
The problem with the Firestone TransForce's is that they are not steel sidewalls like the R250's unless they have recently changed their composition...
Yes, Bridgestone and Firestone are the same company, just 2 different product lines. The difference between a Bridgestone tire and a Firestone tire is that Bridgestone uses a dual tread compound, so as the tire wears, the lack of tread is compensated for by softer rubber. Firestone is a single tread compound, which is why it is less expensive. My coach has traction weakness in snow, but I have found the Transforce to be very exceptable traction wise. Been running them for 8 years (multiple sets)
Feb-05-2014 05:04 AM
Feb-04-2014 06:19 PM
Feb-04-2014 06:03 PM
Feb-04-2014 03:59 PM
rgatijnet1 wrote:wny_pat wrote:
I went with the Firestone FS 560 Plus 9R22.5 on my coach. Have champagne taste with a hard cider income. And I wanted a tire made in the USA, which the Firestone was.
I believe that Firestone tires is owned by, or a part of, Bridgestone USA.
Feb-04-2014 03:35 PM
Bud
USAF Retired
Pace Arrow
Feb-04-2014 03:22 PM
alandsusy wrote:
Guys, look at the warrantees!@!!! IMHO, Michelins are the best you can buy by far, and the cheapest in the long run.
Plus, they are made in the USA!!!
Feb-04-2014 02:21 PM
Feb-04-2014 12:56 PM
Feb-04-2014 12:06 PM
Feb-04-2014 10:03 AM
Feb-04-2014 09:45 AM
Feb-04-2014 09:07 AM
