Tires on blocks/pads for winter storage?
stroza99
I was wondering what you all do during your winter RV storage. We park our MH on a grass/dirt area next to our house. During the season I notice that the front tires sink into the ground a bit when there's a lot of wet weather.(not a lot, maybe an inch or so) Do you put pads/blocks under the tires to keep it off the ground? Or do you just park it? If you do use something under them what do you use? Wood? Plastic? Leveling blocks? I know wood holds the moisture and was looking for some better ideas. We just put 6 new tires on in April and want to keep them in the best possible condition! Thanks for all the input! I Love this site and use it all the time!!
2014 Jayco Jay Flight 33RLDS
โ€œLife is not a journey to the grave with intentions of arriving safely in a well-preserved body, but rather to skid in sideways, thoroughly used up, totally worn out and screaming... Holy Cow!! What a ride!โ€
10 REPLIES 10
Lobstah
stroza99 wrote:
Lobstah wrote:
I'd be more concerned with the body/frame of the coach. Parking over grass is generally a bad idea as it provides a constant source of moisture, and you're likely to end up with more corrosion on your undercarriage.
If it's the only choice you have, then I'd put a tarp over the ground/under the coach.
Jim
Thanks for all the input, but a tarp under the MH? I would think that soaking water into the ground would be better the pooling water on top of a tarp, No?
thanks again all!
Not really. Water will run off the tarp and/or evaporate. The ground, especially ground with grass/weeds, will hold water like a sponge and create a very humid environment. Ask anyone who's parked a car or truck on a lawn for an extended period of time, or go ask a mechanic what happens when you park over grass.
Jim
2005 Pace Arrow 36D
Very Understanding Wife
1 Boxer ๐Ÿ˜ž
3 Maine Coon cats
stroza99
Jim
thanks again all!
Ka_Ron
Jim
To say nothing of rodents
egh33
I park ours in the carport on a concrete slab. I always put the tire covers on even if it is just for a couple of days or all winter long.
Livies_Dad
I park mine on gravel in my back yard now. First couple of years was just grass & dirt but saw how quickly the rust started underneath. I always park the tires on treated plywood and cover the tires.
Dale_Traveling
Something a little more permanent would be to place concrete pads just for the tires, front and rear. Even a couple of inches of gravel or crushed concrete would be better than dirt for long term health of your tires.
2006 Hurricane 31D built on a 2006 Ford F53
Lobstah
Jim
2005 Pace Arrow 36D
1 Boxer ๐Ÿ˜ž
3 Maine Coon cats
2oldman
Old tire storage thread
bluwtr49
I use two pads of 5 railroad ties each for the coach to set on. Works perfect.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
Ka_Ron
We just park ours.
The storage lot we have to use has dirt and gravel.
I don't bother with blocks of any kind.
