Jun-03-2018 09:01 AM
Jun-04-2018 07:40 PM
Jun-04-2018 07:23 PM
j-d wrote:
We have an AM IV hand flush, cheapest thing Thetford makes. Still, it works just fine.
AM IV Parts
13168 Valve Kit $27 Amazon
Jun-03-2018 09:10 PM
Jun-03-2018 08:48 PM
j-d wrote:
Most likely the "flush valve", "water valve" or whatever the parts list calls it. Or a problem with the linkage from the Hand or Foot Control that activates said valve. Possibly some foreign object is keeping the valve or linkage from closing.
Post Brand and Model of Toilet and we can try to find a parts list. Parts aren't cheap, so new toilet may be in order. When you repair or replace it, you'll need a new Seal Ring (prevents leaks between Toilet and Floor Flange, and it's Foam Rubber not Beeswax like we have at home), AND!!! Install a shutoff valve in the line supplying the Toilet. Then you can still use the rest of the RV's water system.
Jun-03-2018 08:36 PM
Jim@HiTek wrote:
Most of those RV water pumps have the fuse for the pump just a few inches from the pump itself. Usually within 6 inches. Find the pump, and the fuse will be there.
Jun-03-2018 08:33 PM
j-d wrote:
This is a "push-on" PVC valve for 1/2" PEX or Copper. This is Amazon. I got a similar one at Lowe's.
Jun-03-2018 08:31 PM
ncscz wrote:Yes ... Water is running into the toilet bowl after its been flushed and keep on running. The only way I could think of to stop it was to shut off the DC to the RV. That worked ... but it also shuts down the Refrige as the DC, I believe activates the Control Panel AC to the unit. Maybe I should try to locate and remove the fuse for the water pump for now and than see if I figure out How to get to the flush valve on the toilet bowl, etc. Thanks for the suggestion I believe that is the cause of the problem.
Does the water fill the bowl and overflow? If the sliding blade in the bottom of the toilet does not seat completely back into the groove the water can continue to flow. If SOMETHING is keeping the blade from sealing, that can cause this problem.
Jun-03-2018 05:49 PM
Jun-03-2018 02:06 PM
Jun-03-2018 11:48 AM
Jun-03-2018 11:43 AM
Jun-03-2018 11:08 AM
Jun-03-2018 11:07 AM
Jun-03-2018 10:09 AM
Jim@HiTek wrote:
Can you see water running into the toilet bowl after you've flushed? And it keeps running? That's probably going to be the flush valve on the toilet. Easy to replace, not that expensive.
Can't see water running into the toilet bowl? Do you see water on the floor of the bathroom? Or dripping to the ground underneath the RV? Then you likely have a split pipe, bad valve, or a bad water pipe connection somewhere. Might feel around the piping going to the toilet for drips of water.
The pump is pressure activated. Turns it on if the pressure drops (by turning on a faucet or toilet valve or caused by a leak) turning it off when the pressure reaches 45 PSI. So if there's a leak somewhere, and the pump switch is 'On' (most RVs have a 'water' switch in 1-2-3 places in the RV where you can switch the pump on or off), that leak causes a loss of pressure, which causes the pump to run to bring it back up.
That's a fine suggestion. Hopefully I may be able to locate a switch directly responsible for the Water Pump. So far, other than that I have a switch to shut off the DC for now. As you mentioned it appears that the flushing lever valve probably have stuck on. Thanks again. All I will need to do/know is how to get to the valve assembly. KC
