Toliet trouble
mercedesme28
Ok,this is detailed, I've taken this toliet apart many times over the years replacing gaskets here or there but now I'm uncertain...at first I thought it was the spring Cartridge, so I had that replaced, and the step Lever would no longer move open and close smoothly...I'm now thinking it might be the sliding ball and crank post which attaches to the spring Cartridge, so does anyone know if this sounds right ?
And if so is this a easy repair ? I know I would have to remove the base and work from the underside....
So if anyone has a. Comment I would be very thankful...
Thanks in advance
8 REPLIES 8
TechWriter
mercedesme28 wrote:
I guess I should just buy a new one, but I've now replaced every part of this unit,( but the ball) over the last year..be my house or RV, never ending work lol
That's what I did. Since you have to remove the toilet and turn it over to replace the ball assembly -- with no assurance that it will hold water when you're done -- I decided to just get a new one (about $300).
2004 - 2010 Part Timer (35โ€™ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41โ€™ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31โ€™ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
mercedesme28
So if the bowl is now removed, the spring also taken off and yet the ball is still having trouble slide back and fourth does that mean that the ball and/ or cam shaft is bad ? What else could it be with everything taken off or apart ? I can move the ball with my fingers( in a glove) but using the pedal it cuts like its stuck and is hard to open and close ?
mercedesme28
Thank you, I think that is my model number and type as it sounds like what I was looking at. I just wanted to make sure it didn't take a press to to the new part in or not.
Do the newer toilets use something different then the ball flush ?
Thanks again
wa8yxm
If that is a sealand 110 or 111 type (Ball flush) you have to remove not only the bowel from the base but the base from the floor as well.
After that it is very easy. Pull a screw, Tap the end of the shaft gently to force it into the base.. Remove it, Remove the ball, drop in new ball, new shaft and new screw.. Very easy.. I do not recall if the new shaft and spring cart were in the kit (Think they were but not sure)
tomousecap
I fixed ours by just replacing it with a Thetford "Style II" works great now and not much hassle and messing around. Glad I got rid of the original no count loser stool.... ๐Ÿ™‚ Replacement cost no big deal and now warranty in force. Cost around $156 online.
OnEdit: I will admit that they all seem to suffer from certain water supply problems. Ours doesn't like the high calcium content in the Rio Grande Valley water. The Thetford however is easier to change the seal if needed and the ball seems to work well all the time unless calcium buildup occurs. (about every 1.5 to 2 years of use for us.)
Bob
2007 Fleetwood Bounder - Full Paint 35E
Workhorse 6 Speed 496 Cubic Inch V8 - W22
Ford fans - RPM is a poor substitute for Cubic Inches!
2013 Chev Volt - Towing on a Master Tow Dolly
Gracie = Adopted longhair Amazon Chihuahua
want-a-be
We had problems with ours and when I took it out I tighten up all the bolts and screws,
Come to find out some are suppose to be a little loose so parts can move.
Hope this helps??? Good Luck
mercedesme28
Oops I'm so sorry,
It's a older Bounder with a travelers toilet with a Porcelain bowl...
CloudDriver
Kind of hard for anyone to reply without knowing the manufacturer and model of your toilet.
2003 Winnebago Minnie 24F - Ford E-450๐Ÿ™‚
