โJul-18-2013 05:27 PM
โJul-23-2013 09:07 AM
carringb wrote:theotherbart wrote:
I did manage to get my hands on the sales brochure (someone at Thor e-mailed it to me). It lists a GCWR of 13,500 pounds.
Keep in mind that the same chassis with the big block was rated for 16,000 GCWR. So its not like the motorhome is going to fall apart if you exceed 13.5k. Main limitation is really power and gradability (At 13.5k, 15% will be about the steepest you'll be able to take off from if stopped). Also the transmission will probably benefit from more cooling if you run heavy.
โJul-23-2013 09:02 AM
โJul-23-2013 08:51 AM
โJul-23-2013 07:23 AM
Healeyman wrote:
Until a month ago, we RVed for 11 years in a 1999 22' Four Winds 5000 on a Chevy 1 ton chassis with the 350 CI Vortec V8.
My 4 Winds had a 5,000# hitch and many times, I pulled an enclosed trailer (2,000#) with a sports car (2,400#) inside from Dallas to both coasts.
I spent much of my career designing and building mobile military hardware/vehicles and experience suggests that your hitch probably has a designed-in 200% or 300% safety factor. For example, we'd regularly tow 25,000# aircraft with the 5,000# hitch on a HMMWV (=Hummer).
That said, because I was right up against my rated hitch capacity, I installed VERY heavy safety chains from the trailer frame to the RV frame. I never attach safety chains to the trailer tongue or to the RV hitch.
I'd upgrade the hitch and go have fun.
Tim
โJul-22-2013 05:14 PM
โJul-22-2013 04:27 PM
Snowman9000 wrote:
My opinion is that you probably don't have any frame extensions on such a short MH. So if you subtract your actual loaded weight from the GCWR on the door or glove box or from the chassis manufacturer data (not the MH manufacturer), the difference will be your towing capacity. Once you install a hitch rated to same. I could give you my Chevy's GCWR but mine's an 04 chassis with different powertrain. Off the top of my head, I think mine is 16,000.
I suspect you'll find you can tow the Jeep within the limits.
โJul-21-2013 04:54 PM
โJul-21-2013 04:38 PM
Francesca Knowles wrote:
I'd ask the manufacturer what your rig can safely tow- but if the only info you have to go on is the GVWR and the(OE?)hitch limit, you might add those two numbers together and presume that's your GCWR. 3,500+12,500=16,000.
Next,weigh the loaded rig. No cheating! It has to be loaded for the road, and allow for you and any companions, too. Add the weight of Jeep, also loaded.
If with all that you're under 16,000 you're probably fine- but do change that hitch, please.
โJul-18-2013 07:27 PM
